  • Guests: 32
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
0 to 50V 5A power supply.
Chris Cristini
Sun Dec 14 2008, 03:44PM Print
Is It worth buying. Link2
El_Roberto
Sun Dec 14 2008, 10:50PM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
For that price I would make one myself, Also its only 5A...
Sun Dec 14 2008, 11:57PM
Well, you can parallel the two outputs for 10 amps at 50 volts, or series for 100 volts at 5 amps. But i must say, making your own would probably be much better. Just rewind a mot, and use a variac on the primary side for variable voltage. It is not regulated, but for something like a zvs driver, regulation is not needed. Neither do sstc's. Or anything like that that drives a transformer from a dc supply for that matter. Rewinding a mot is very easy and you can get the voltage that you need, and the are good for usually at least 800 watts continuous, and for something that doesn't run for too long, you could get much more.
Mon Dec 15 2008, 12:03AM
Digital panel meters in PSU's are often very vulnerable to rogue high voltage pulses traveling back along the supply rail - so take care if you buy something like this. More than one member of this forum has fried their PSU digital display during HV experiments.
aonomus
Mon Dec 15 2008, 12:08AM
Another alternative is a big smoothing cap, a bridge rectifier, and a variac. It'l give you as much voltage with however much current you could want (within reason).
Mon Dec 15 2008, 12:37AM
It depends on what you are trying to do... If you are trying to run SSTCs, the variac+bridge rectifier+smoothing cap will be cheaper/more robust. If you are using it as a general lab supply where you want something that is smooth, stable, etc, a dual 5a supply is great for running little logic circuit and the like,
Hazmatt_(The Underdog)
Mon Dec 15 2008, 04:00AM
Yea you "could" make one, provided you had the heatsinks, transistors, transformer, and meters already purchased, but at this point its almost the same cost.
IF you are doing some experimenting like building amplifiers (I am playing with some right now) then the dual tracking is a really nice feature. Or if you are designing non-high voltage related things these are really good, but get one with V and I readouts so you don't have to switch back and forth.
Never use these things for Flyback stuff, or nice signal generators, I wiped out my BK 4017 doing that.
Other then that, having these as lab supplies, yea I think its worth it. I paid about that much for LG supply that retailed for over $400 a few years ago.
aonomus
Mon Dec 15 2008, 05:57AM
Strangely enough my made-in-China 30V 5A PSU has run a 2n3055 flyback driver, and even my SSTC without any issues... any ideas why my PSU isn't dead yet?
Electroholic
Mon Dec 15 2008, 11:35AM
aonomus wrote ...
Same, I used mine driving an ignition coil once, it does have analog output meters tho.
If you don't have a lab PSU already, I would say definitely get it. Very handy to have around.
Chris Cristini
Mon Dec 15 2008, 01:57PM
OK I am going to buy it thanks for your Pro's and con's. High voltage is not the only thing I do the other day I made an audio amp and I used my rewound MOT but it did not work to good. And I repair car radios and other things for a little cash here and there so it might be a good idea to have a power supply so I don't have to use a 250w computer PSU all the time. smile
