  • Guests: 43
ZVS SSTC.
Chris Cristini
Sun Dec 14 2008, 04:35AM Print
Is it possible to use a ZVS driver on a SSTC I hear it is but I cant seem to figure it out.
Sun Dec 14 2008, 05:10AM
crazy4 wrote ...
Well, use a 6 turn center tapped primary and have at it ^.^. Just use a different tank cap. I dont know what to use though, but something like .1uf to maybe .5uf might do it. Experiment.
Anon01
Sun Dec 14 2008, 05:30AM
Anon01 Registered Member #1589 Joined: Sun Jul 13 2008, 06:40PM
Sounds like a DR. xD
jovica
Sun Dec 14 2008, 07:06AM
jovica Registered Member #1790 Joined: Fri Oct 31 2008, 10:10AM
Yes it is very possible, wind 3+3 turn primary on your secondary and hook it up on your driver.
The tank cap need to be approximately 0.1 uf depending on your secondary dimentions, and also the capacitor need to be of high quality, you may even need to make a mmc as it get very hot.
I have actualy done this before
Video @ Link2
This run was on 12 volts so much better results should be expected on higher voltages.
Sun Dec 14 2008, 11:06AM
The ZVS was originally a SSTC driver invented by a guy called Mazzilli. He was using 1200V IGBTs and geting about a foot of sparks. It was adapted to flybacks later by the good people of this forum.
The Skori coil is a more recent SSTC with a ZVS-style circuit.
LithiumLord
Sun Dec 14 2008, 01:42PM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Hmm, something's telling me the answer is very close ;)
Chris Cristini
Sun Dec 14 2008, 02:14PM
Thank u for your reply's I am off to build one.
