  • Guests: 59
Need help getting started on HV
1 2 3 4
Cwiber92
Sat Dec 13 2008, 02:55AM Print
Cwiber92 Registered Member #1858 Joined: Fri Dec 12 2008, 05:17AM
Hi I'm trying to build my first HV circuit using a flyback transformer I extracted from a somewhat old CRT TV. I'm looking to build a 555 timer-based driver first and then possibly move onto a ZVS driver.
So my big problem right now is identifying the primary and secondary coils on my flyback and figuring out how they should be configured. I don't understand what's going on when I see flybacks like mine with coils added on the outside bar. Is that a newly wound primary? Do I want to do this? I'll just assume for now I want to leave my flyback as is.
Regardless of what driver I use are the output terminals located on the suction cup and the 0V point on the secondary? The two methods I've found for finding the 0V point are from http://leoricksimon.blogspot.com/2007/05/flyback-driver.html and http://jnaudin.free.fr/lifters/labhvps/tht.htm. The first method involves using a high resistance-reading multimeter, which I don't have and the second involves a 24VDC power supply, which I don't have on hand right now either. Is it possible for anyone to identify which pin is which by looking at my pictures before I set out to build a 24VDC power supply? I think I've got the primary right though. Isn't it polarity sensitive?
The 555 timer driver I plan to use is from http://www.electronics-lab.com/projects/misc/016/index.html. Does this look good?
Any response would be greatly appreciated.
Thanks
1229136919 1858 FT0 Flyback
1229136919 1858 FT0 Picture2 039
1229136919 1858 FT0 Picture2 041
Coronafix
Sat Dec 13 2008, 03:02AM
You could just series some batteries together to get 24V.
For the primary, it is best to wind about 10 turns of enameled wire on the exposed core.
teslacoolguy
Sat Dec 13 2008, 03:03AM
Don't waist your time finding the existing primary coils. Just wind your own of 10-12 turns on the opposite exposed core section. The suction cup is the hv anode (hv +) and the hv ground is one of the pins on the bottom of the flyback. The easiest way to find out what pin it is, is to get the driver working and then by bringing the hv anode wire near the bottom pins, the one that it arcs to the most is the 0v pin. I hope this helps.
jovica
Sat Dec 13 2008, 03:09AM
jovica Registered Member #1790 Joined: Fri Oct 31 2008, 10:10AM
Hi,
I think you will be better off by just winding your own primary on the exposed part of the ferrite core. There seems to be enough room to wind it.
For the HV ground identification, just bring the big red wire near the pinout at the bottom and , it should start arcing to gnd when you turn the driver on.
EDIT: Got beaten to it.
Sat Dec 13 2008, 03:15AM
Hello, and welcome to the forum! Well, to find the primary, just use either inductance meter, resistance meter, or a simple light in series with a power supply with same rated voltage as the bulb. Just scan the leads, and the one with lowest inductance or resistance is the best primary. If you do not have either of those, you can put some sort of low current load(lightbulb or small dc motor) in series with the output of a power supply rated for the load. When even you find two pins that have continuity, it would be a primary. You will probably find two low resistance windings, and one high one. The lowest resistance is better.
You can just wind your own primary though. For a 555 driver, around 10 turns will do fine. The internal primary seems to work better for me though. If you still have the circuit board that it came off of, look on the bottom side where the flyback pins came from, and it might have markings telling you what are primaries, etc. To find the hv return(0v, what ever you want to call it) pin, just bring the hv wire close to it and the one it arcs to readily is it. Do not let it hit the wires from the driver though.
The ZVS is very simple but the ultimate simple flyback driver. It creates such little heat it is truly amazing. On my ZVS running at around 600-800 watts, the 12 gauge wires heat up more than the mosfets! Also, once i had an arc hit the wire leading to the mosfet, and it did not die. Nothing was damaged! The strangest thing is that i am using a 4 amp bridge rectifier, which does not die after a few minutes of running, even though i pull about 18.5 amps max, and 15 amps continuous. But be careful, when using the ZVS at higher powers, expect to kill some flybacks. Not because of excessive voltage, it is the current and heating that kills it! And it was the diodes most of the time on mine. I killed 3 flybacks yesterday, as well as a homemade one, and i killed one today :).
Hazmatt_(The Underdog)
Sat Dec 13 2008, 08:27AM
You have the correct primary there! surprised?
I had a driver of exactly what you're talking about on my webpage...unfortunately... aol killed it, but I can see if I have the pictures buried somewhere if you like.
Sat Dec 13 2008, 11:49AM
I prefer flyback mode myself,
you can push a lot of power through a flyback transformer using zvs,
but there is very little protection for the very fragile secondary winding and diodes,
and the output voltage is fixed at maximum continuously.
A simple 555 driving a mosfet or igbt won't be as impressive,
but it is more reliable, and the output power is usually easily adjustable.
You must protect the switching transistor for reliability
- a snubber or clamp or resonant cap is required
(or an avalanche rated transistor and a big heatsink)
- I always use a diode clamp for the gate to 555 0V and +V.
- a fuse between the transistor and the dc smoothing/reservoir cap is a good idea.
The most efficient operation will be using the original secondary winding
because it is closely coupled (magnetically) to the secondary
so there is less leakage flux energy to dissipate each transistor turn-off.
Unfortunately this means about 100 to 150 V dc supply
which is neither convenient (unless you have 110-120 Vac supply) , nor 'safe'.
So initially you should wind an external primary as advised above.
That way everything can be powered by a battery or low voltage psu.
Sat Dec 13 2008, 12:57PM
Sulaiman wrote ...
Just to clear things up a bit, if you're gonna draw arcs from the transformer (and I think you are tongue) , then you absolutely NEED the leakage inductance if you don't want to bake something.
So, winding the the primary opposite the secondary has these advantages: 1) the resulting leakage is usually about right for normal arc-drawing or other projects, 2) if it smokes you can wind a new one. If you fry the internal one, not only you can't rewind it, but usually the whole transformer is ruined because the winding often contains shorted turns.
For flyback-mode TV transformer driver, I prefer to use this one (the QR driver as I call it, you can get very high voltages out of the transformer. I also have a schematic with smps IC which allows control of output power, just let me know if you want to see it)
1229173170 152 FT59399 Qrdriver555 En
Cwiber92
Sat Dec 13 2008, 07:41PM
Thanks for all of your replies! I'm going to wind my own primary and order the parts for both a 555 and ZVS driver. I have 18AWG enameled magnet wire, will this work for the primary? I plan on using the schematic suggested by Mr. Kilovolt. When you wind your own primary how do you tell which end is (+) and which is (-)? Will 1/4W resistors work? Must the 555 timer voltage be 15V? I have a 12V @ 2.5A power supply on hand, will that work?
As for the ZVS driver, what wattage should the 10K resistors be rated at? What is the function of inductor coming off of the centertap? Does its inductance depend upon your power supply/primary windings or will anything between 47 and 200uH work? Should I be looking under power inductors to find it online? Should I be looking for 400+V diodes and not rectifiers, or will they function the same?
One other thing I'm not so sure about is what power supply to use for the ZVS. So no matter what voltage between 10 and 40V I select, it must be able to pump out 10 or more amps? And does more voltage mean more primary coils? Does anyone have any power supply/primary combos they can share?
Thanks
Sat Dec 13 2008, 08:04PM
Cwiber92 wrote ...
I would suggest an insulated PVC wire for the primary, it does not need to be very thick (standard "bell wire" will work). You can use enameled too but the insulation can easily get dented by the sharp edges of the ferrite core.
All resistors are 1/4W.
As for the polarity, just try both and use the one which gives bigger spark.
12V will work too (you can decrease the gate resistor to 560 ohms).
I'd suggest starting with lower voltages for the power part (e.g.12V) and then go higher, the absolute maximum is around 35 volts with the components as in the schematic. The driver can draw up to 200W so make sure your PSU can handle it.
