  • Guests: 64
MOT's
Chris Cristini
Wed Dec 10 2008, 05:37PM Print
I cant seem to get the secondary out and when I do what is the best way to limit the current that it will draw from 120v mains my MOT is a beast but the wiring is crappy in my house.
1228930610 1749 FT0 13
rp181
Wed Dec 10 2008, 09:39PM
Do you mean taking out the secondary windings out to replace them? If so, you can just hacksaw the windings and pull them out.
For ballast, light bulbs work, high wattage for more current draw.
Chris Cristini
Thu Dec 11 2008, 05:19AM
My MOT/ZVS I had to use heat it was a pain in my ass but I think it works OK. Any one have any suggestions on smoothing and rectifying? Be much appreciated. cheesey Link2
1228972551 1749 FT59249 100 0747
1228972551 1749 FT59249 100 0748
1228972551 1749 FT59249 100 0751
teslacoolguy
Thu Dec 11 2008, 05:28AM
Use a 25A bridge rectafier on a heatsink and a 10,000uf smoothing cap.
Chris Cristini
Thu Dec 11 2008, 03:05PM
Could I use four of these high speed glass passivated diodes for a bridge rectifier.
]hfa25pb60_ultra_fast_recovery_diode.pdf[/file]
