  • Guests: 43
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Wind generator monitoring board(s)
TheMerovingian
Tue Dec 09 2008, 09:53PM Print
The project is in its final stage (calibration and software debugging).
It consist in two pic16f876a microcontrollers, two LCD display a TLP434-RLP434 radio transmitter-receiver pair and various opamps and comparators.
The tower side board acquires alternator voltage, alternator current (now using a copper strip for shunt ,next using a constantan wire 1mOhms shunt), battery voltage, alternator phase frequency (RPM calculation) and anemometer (counting the impulses from an optical sensor interrupted by the rotation of the anemometer shaft). Through calculation it determines TSR, rotor torque, power, integrates the power to get energy in KWh and wind statistics. It also sends on-air a packet composed by the five basic parameters (voltages etc), the remote-side-board receives it and performs the same calculation separately from the tower-side board, displaying the same information. Both circuits are operated by a single button interface (short press cycles through modes, long press resets the statistics). The tower side operates also without LCD display, the remote side obviously not, since it purpose is to show the contents of the packet
1228859606 14 FT0 Cimg1649b
1228859606 14 FT0 Cimg1650b
1228859606 14 FT0 Cimg1634
1228859606 14 FT0 Cimg1651
TheMerovingian
Mon Mar 02 2009, 02:30PM
UPDATE:
The project it's finished and it is installed on-site. Waiting for wind to calibrate my anemometer.
Final Features:
-Real time monitoring of alternator Voltage ( xx.xx V), alternator Current ( xx.xx A), Alternator Rotation speed (RPM), wind speed (m/s) and derived data (Alternator Power, TSR, Torque)
-Backup Battery control and charging display
-Wind statistics (Absolute average, wind average, wind maximum), and power counter (KWh xxxx.xxxxxx)
-Possilibity of tuning the system to change voltage/current ranges, rotor diameter, anemometer calibration, alternator poles (RPM calculation)
-Packet broadcaster (symple cryttoigraphy) with the acquired data (one every 0.5s)
-1-button interface for changing page, resetting and adjusting parameters
Features of the receiver:
-Shows the same data of the transmitter, logs power produced and statistics indipendently from the transmitter, two RPM and Wind led alarms, 1-button interface
The station turns automatically when over 150 RPM (cut-in of the turbine)
Let me know if you like it :D
1236004248 14 FT59207 Cimg1854
1236004248 14 FT59207 Cimg1855
1236004248 14 FT59207 Cimg1856
1236004248 14 FT59207 Cimg1857
1236004248 14 FT59207 Cimg1858
1236004248 14 FT59207 Cimg1859
1236004248 14 FT59207 Cimg1860
1236004248 14 FT59207 Cimg1861
1236004248 14 FT59207 Cimg1862
1236004248 14 FT59207 Cimg1863
GeordieBoy
Mon Mar 02 2009, 02:45PM
I like the little wind turbine symbols and lightning bolts on the LCD screen - Did you do these with user defined characters?
TheMerovingian
Mon Mar 02 2009, 03:15PM
Yeah, there are simple LCDOUT command to define them(in picbasic)
if i remember correctly it is:
LCDOUT $FE, x , byte0, byte1, ..., byte 7
x is the character location (0 = 64, 1 = 72 and so on with 8 byte increment for each char)
byte0...7 are the pixel bitmap definition byte
The simbols are a pain to design having a 5x8 matrix :D
but they work and work good
Mon Mar 02 2009, 06:54PM
Neat project, but the box with display and control in, is it weather proof?
TheMerovingian
Tue Mar 03 2009, 11:44AM
THe box is weater-rated (for external areas). The lcd has a silicon gasket and a polystirene window, so the water will not get in. In these days it is raining but no water gets inside
