  • Guests: 32
Something to Do with All Those Extra HOTs
Firefox
Thu Dec 11 2008, 06:27AM
Update! I tried a couple toploads. Anything that is smooth prevents breakouts, but with a 9" breakout point from a semi-toroid made from the bottoms of two popcans (which fits perfectly on the secondary), I can get 9mm dual flames on the tip of the breakout point. Current draw is increased to 1.11A @ 23V. 2mm gain for 3W is pretty good, I think. amazed
Update update: Turns out, the real issue was getting the breakout point away from the coil. Without the topload, but with the remote breakout point, I can get the same 9mm dual flames, but with the 1A draw.
Firefox
Thu Dec 11 2008, 10:51AM
New problem. The oscillations start around 5V, drawing 450mA or so and go right up to 25V drawing 1.4A. However, once I pass that point, the oscillations stop, and the circuit starts drawing about 2.5A and heating the transistor.
