  • Guests: 38
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
Apparently around 20 microwave caps is enough to explode stuff?
Myke
Fri Dec 05 2008, 11:04PM
I think that most of the bleeders are 10Mohms so it would dissipate ~6.4W at 8kV. The bleeder resistor only dissipates .4W at 2kV.
Sat Dec 06 2008, 12:03AM
Well, i was not suggesting to use MO caps. I honestly wasn't. I was ust comparing my cap to them.
My cap is now dead, as well as a few hv diodes and a freaking MOT. I sure had fun. I crushed some cans, one was close to ripping apart. This was at 100 joules though, and 4kv. Capacitance does not matter that much with exploding stuff and crushing stuff. It all depends on discharge current. You can have a cap with a small capacitance(like my cap) and it can still do these things if it is charged up enough. So joules is higher energy, but it is how much energy over time. So you do not need like 1kj to explode stuff, just a highish voltage capacitor that is good and discharges very fast.
Backyard Skunkworks
Sat Dec 06 2008, 12:58AM
Arcstarter wrote ...
Whoa, what happened?
Sat Dec 06 2008, 01:33AM
Idk. Guess i deserved it..?
I guess it reverse charged, as the diode blew and has a crack down the THICK case of it. I am sad.
Sat Dec 06 2008, 11:04AM
Billybobjoe wrote ...
MadsKaizer wrote ...
But its not worth the time getting them compared to finding some bigger lyttics or pulsecaps, atleast dont invest money in it.
I disagree with that statement. Have you checked the prices on pulse caps lately (even on eBay)? Electrolytics are cheaper but then you need a massive freewheeling diode and they're slow, even compared to MO caps. See Steve's page here (again): Link2 The ESL is pretty good considering the price.
Thanks to Steve Ward's idea I obtained 25 MO caps from a surplus site for $1 a piece. I'll get some pics of my setup later but it crushes cans and explodes wire like a champ. I've shot some 40 shots off with my bank (at between 6 and 7kv) and they are still holding strong.
Hmm maybe I should rebuild the setup he used then, but in your fashion as it sure sounds to work nicely. We just didn't have much luck with :(
Im looking forward to see your work :)
Billybobjoe
Sat Dec 06 2008, 04:35PM
Billybobjoe Registered Member #396 Joined: Wed Apr 19 2006, 12:55AM
I don't want to hijack this thread so if a mod wants me to move this to a new one I will be more than happy to.
Here you can see the switch. I wanted it to be fairly quiet it consists of two solid brass cylinders ~1cm. diameter soldered into two threaded bushings which are threaded into the PVC pipe fitting tee. These are separated by a distance that would allow an arc at normal atm. pressure, but not when the fitting is pressurized. Pressure is supplied by a small bicycle shock-pump which works well because the volume in the system is low. The pressure is released first with a handheld valve, which releases the pilot air which triggers the QEV (quick exhaust valve) to exhaust the tee as quickly as possible, firing the gap. It is fairly quiet because the sound of the pressure being released is nothing compared to an open spark gap firing at 650 joules.
DSC03684
These are the "charging resistors". They really aren't for charging, but provide overcurrent protection for the diodes from the reverse voltage spike when using and inductive load. I blew a lot of diodes before some members helped me out in this thread:http://4hv.org/e107_plugins/forum/ forum_viewtopic.php?20670.post
DSC03682
The bridge rectifier - uses 3 amp BY255's because they have a 200 amp peak rating so can handle the resistor dampened voltage/current reversal.
DSC03685
Long extension on the controls to permit firing from a distance.
DSC03678
High voltage probe, pressure gauge, filling valve (schrader style), charging switch w/neon indicator, and firing valve.
DSC03687
Sun Dec 07 2008, 01:57PM
Billybobjoe that is a really nice setup you got there, and from your linked thread I can see we made the same mistake not having resistors to protect the diodes.
If you got 650J you are charging them to about 5.2kV, if they are combined at 24uF.
Are all the caps the exact same of did you just use 24 mixed ones?
I got 12x 1uF/2100Vac that exactly the same and an additional 8 mixed somewhere between 0.85-0.97uF 1900-2100Vac.
With the 12 I could get 381J at 5,6kV or with all 20 636J at 5,6kV, this is if I can use a small SSNST I got lying around 4kV/20mA. Rectified its around 5,6kV.
Really cool trigger mechanism, might be a thing to do after, when you said yolu used a chock pump, is that just a normal bicycle pump?
Billybobjoe
Sun Dec 07 2008, 04:28PM
Thanks. I figured something was wrong when I spent two hours setting up a full wave bridge rectifier rated for 20kv using 80 1N4007's only to have them killed in a few nanoseconds. The 650J was just an arbitrary number - the voltage I charge them to depends on what I'm trying to accomplish and how brave I'm feeling.
Mine are all exactly the same - Aerovox 1.02uf 2200 VAC
I don't immediately see a problem with using two different kinds - if you keep the voltage relatively low like you plan then your chances of failure are somewhat lower.
A shock pump looks like this - Link2 (I think thats actually the exact one I have . . .) I used to use a regular pump until a friend gave me the smaller more portable shock one. With a full size bike pump and a low volume system, its difficult to get a specific pressure without going under/over - but to conclude if you already have a bike pump it probably wouldn't be worth getting a shock one as well.
Myke wrote ...
This sounds correct but when I bought my capacitors I got an extra to do some initial testing on. I charged it repeatedly to 10kv then discharged it into a short. I had to do this with a chicken stick because the cap. would discharge by itself very quickly. After maybe 20 shots it did get fairly warm on the outside metal case, so I'd imagine the inside was even hotter. I wouldn't be surprised if this led to the failure of the capacitor in Steve Ward's test (mine never failed). I'd like to do the test again but the NST I used is now integrated into the can crusher shown above and that would require a bit of effort to free it up for use (I'd be happy to do it if anyone was really interested though).
Sun Dec 07 2008, 09:01PM
Its hard to tell, but I think your resistors are 3K5 330W, which seems rather big considering the math suggested in your thread.
R>Vmax/Ipeak during discharge
Also R>V/Irms during charge
But it only means that I need to find a resistor bigger than what the calculations tell right? The bigger the slower it will charge the bank.
Billybobjoe
Mon Dec 08 2008, 01:49AM
They are 1500 ohms (you do mean my reverse EMF protection diodes correct?) They just need to limit the current through the diodes to their peak rating (200 amps). My setup limits the current to 5.33A = 8000V/1500ohms (Assuming the reverse voltage is the same or less than the charging voltage when it rings down). There is definitely some leeway built into my system and that's generally a good thing.
