  • Guests: 66
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
Steve's Micro SSTC building tips
Birdman
Wed Dec 03 2008, 05:37AM Print
Birdman Registered Member #1704 Joined: Fri Sept 19 2008, 08:54AM
Hello all,
I am beginning to build Steve Ward's Micro Tesla Coil
It is my first SSTC. I have finished the electronics, but i am waiting on the TC4420 to arrive in the mail. I was wondering if anyone could help me with my design before the big power up....like is the arial too long?
I have powered it off 20V with no chips(to test if it was wired correctly), and the 12V regulator became quite hot quite quickly. Was this because there was no load on the rest or the power supply? or because of other reasons...
I will run it off 35VDC @ 50VA(~1.5A)
In this picture you can see my MOSFET (at the left of the circuitry) which has a large heatsink and fan. You can see the voltage regulator (at the front) mounted on a heatsink.
Any help would be appriciated. Thanks
1228282649 1704 FT0 Sstc 001
1228282649 1704 FT0 Sstc 002
TheBoozer
Wed Dec 03 2008, 10:27AM
I beleive that 35vdc is the upper limit for a 7812. I would prefer to run it around 20vdc. It's dissipating a lot of heat at 35vdc. That's my 2 cents unless I'm missing something...
Dago
Wed Dec 03 2008, 10:40AM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
If the regulator got hot with no load then theres something wrong.
Birdman
Wed Dec 03 2008, 11:01AM
Yeah i just found a bridge on the output of the 12v regulator.
I did another 20VDC test run today, and it is not getting warm at all. It is running my fan, so it does have load.
Thanks for the help
TravisD
Sat Dec 06 2008, 07:35AM
TravisD Registered Member #1658 Joined: Thu Aug 28 2008, 11:27AM
Hey guys I am new to sstc's and I have been looking at some schematics and I have all ways wanted to build one with this circuit but can’t find the accurate parts, Is this a good circuit to make as a beginner and can it power different coil dimensions? I am on holidays now and trying to make a sstc very soon.. so any reply is mostly appreciated
Thanks
Travis....
Birdman
Sat Dec 06 2008, 10:55PM
Yes this coil is very simple compared to full wave versions which are a maze of electronics. I chose to start with this because it is fairly simple to build. It may be limited on the power side of things though. I suppose if you got a better MOSFET and ran the it and the coil off rectified mains, i dont see why it wouldnt work. But i do recommend that you get more experience with low voltage tesla coils before using mains. Or maybe you could use a half or full bridge of MOSFETS to get more power. There are many designs out there.
Hope this helps
Frank
jovica
Sun Dec 07 2008, 01:23AM
jovica Registered Member #1790 Joined: Fri Oct 31 2008, 10:10AM
Hi,
I am not sure of how experienced you guys are with electronics but a tesla coil is quite complicated.
Maybe you shoould mess around with a flyback driver first so you get to know high voltage a little better.
After that you could try a fixed freq.. sstc and then move onto something like this.
Try building a zvs driver and instead of running a flyback with it make 3+3 primary on your secondary, use those 160v 7amp fets from jaycar you should be able to run it up to 40 volts and get very nice breakout. and all the other components are availble from jaycar.
Link2 scheme
Sun Dec 07 2008, 03:25AM
TravisD wrote ...
Thanks
Travis....
Sent a private message yesterday, check you inbox cheesey
Myke
Sun Dec 07 2008, 03:29AM
I don't think that a fixed freq coil would work all the well because the resonant freq would changed when something that is capacitively coupled to ground moves near the secondary.
With a SSTC there shouldn't be any high voltage on the primary side of the coil. All the high voltage would be on the output.
Here are a couple suggestions I would make. I would try to tie everything down so that it doesn't have any chance of moving and shorting something out. You probably want to use a different circuit if you were to move to higher powers.
jovica
Sun Dec 07 2008, 05:47AM
wrote ...
Yes Myke but the whole point is that it is very simple and its a good learning experience, for example:
He goes ahead and builds a simple 555 oscilator and tunes it to the right frequency , and of course gets breakout
He than tries to pull an arc but it stops working he of course starts to wonder why this is so, he than goes on the net and researches this and and find some info but than he does not understand some of the things the paper talks about so he goes to find out the thing he didnt know, he does this on an on and he absorbs a large amount of info in the process
smile
