  • Guests: 62
vasil (55)
zephir (37)
rajheman (34)
08/25 vasil (55)
08/25 zephir (37)
08/25 rajheman (34)
Rotary spark gaps.
Tue Dec 02 2008, 08:27PM Print
Well, since i am making my own arsg, i figured it would be cool to share our rsg projects and ideas. I have not yet finished either of mine(one for small coil, one for larger), but once i do i will post some pics.
teslacoolguy
Tue Dec 02 2008, 10:58PM
1228258486 1107 FT58549 Rsg Done
1228258636 1107 FT58549 Disk
1/2" tufnol
rp181
Tue Dec 02 2008, 11:27PM
Whats the need for such big motors, whats wrong with small ones?
Tue Dec 02 2008, 11:46PM
rp181 wrote ...
Well, i am using a small one, it is only 2 watts :P But of course i am running it on 12 volts instead of 3. cheesey cheesey cheesey
I finished my small one up an it worked great, until the wood decided to become conductive, so now it is a shorted rsg. Need to find some thick plastic man!
teslacoolguy
Wed Dec 03 2008, 01:29AM
rp181 wrote ...
Because big motors are pimp cheesey
The other reason i used it is because i might modify it for step up belt drive so i wanted it to be powerful.
Wed Dec 03 2008, 04:26AM
Use lexan. It has a high temperature tolerance and very strong. Non-conductive with high dielectric.
Anon01
Wed Dec 03 2008, 04:30AM
Anon01 Registered Member #1589 Joined: Sun Jul 13 2008, 06:40PM
*Cough.* I agree with rp181. I'm doing a 14" 1800RPM SRSG with 1/25HP. It is running at synch, but this is ASRSG, but it all can work. Point is, if you have low enough air drag.
Propeller type, but it works, no reason why it wouldn't. 3/16" brass and tungsten on the prop. 1/8" tungsten on stationary.
Hazmatt_(The Underdog)
Sat Dec 06 2008, 08:39AM
Here's mine, using a little sewing machine motor, gets hot but it works pretty good.
The real trouble is it has no optical tracking and the inertia of the gap is a lot for this little motor so regulation is not really possible. This would need a PID controller to maintain speed properly.
Robert2
Sat Dec 06 2008, 09:37AM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Can i use plexiglass for Disk in RSG ? I have 1,1 KW motor from Vacuum cleaner. My plexi is 5mm.
Sat Dec 06 2008, 10:48AM
The official line is: Don't use plexiglass, lexan, a chopping board, the lid of a laundry basket, whatever, for your rotor. They might seem strong enough at room temperature, but they're thermoplastics (google it) and spark gap electrodes, believe it or not, get extremely hot.
Tufnol and G-10 are thermosetting: they don't soften with heat. They're also very expensive, but having tungsten rods removed from your forehead is pretty costly too.
