  • Guests: 59
un potting transformers
Chris Cristini
Tue Dec 02 2008, 05:53AM Print
I found a new style oil burner transformer and id like to get a hold of the secondary but i don't know where to start.
Backyard Skunkworks
Tue Dec 02 2008, 06:17AM
Sometimes the glue is soft enough to pry off. Other times boiling in water softens enough. Yet other times, you need to resort to solvents along the lines of acetone or isopropanol.
aonomus
Tue Dec 02 2008, 06:32AM
Keep in mind that organic solvents that can dissolve the potting material may (likely will) either soften the component plastics, or dissolve the HV winding insulation (leading to internal arcing). Best bet would be first to boil to heat it up, pour/scrape out what you can, then work from there....
Chris Cristini
Tue Dec 02 2008, 09:01PM
I got some of the potting off and there is a circuit board in there i was playing around with it and connected it to a battery to see if it would make an arc and it did it sounded like my zvs driver and I can't get any further with the potting should I let it boil for couple hours or so.
aonomus
Tue Dec 02 2008, 09:10PM
Dunno, but maybe pics might give a better idea as to how to tackle it....
