  • Guests: 33
Very Easy SSTC
NNO2
Mon Dec 01 2008, 02:39PM Print
NNO2 Registered Member #1648 Joined: Thu Aug 21 2008, 06:03AM
Please give my best regards to me in the Japanese though it is not so
good at English.
I developed SSTC that started easily easily very much.
From the Secondary of Tesracoil to direct fathom of signal
It is a circuit that amplifies by the emitter follower and does
MOSFET in the switching.
The square wave of 1MHZ is used with LMC555 for the trigger.
It is a problem that the damage rate of MOSFET is very high.
It is likely not to move according to the transistor and MOSFET for
amplification even though the certainty is high.
1228142269 1648 FT0 20081130sstc
Myke
Mon Dec 01 2008, 02:47PM
Welcome smile
Aren't pins 2 and 6 supposed to be connected to pin 7 with a resistor? I haven't seen any configurations where the output is fed back to the 555.
NNO2
Mon Dec 01 2008, 03:04PM
Because it was a thing made from the improvisation, 555 oscillation circuit was not corrected that it was detailed.
The high frequency that becomes a trigger from this oscillation circuit is output.
When SSTC starts, the output from 555 moves SSTC by using the lack in the feedback signal from Tesracoil and erasing.
MRacerxdl
Fri Dec 05 2008, 12:26PM
The Pin 3 Feedback with a resistor to pin 2 and 6 works good, and gives it 50% duty cycle (that is the difference between the another) , but a buffer is really needed on the output, because if the currents get high on the 555 output, the voltage drops, and the frequency changes (and some times stop to oscilate).
I use that 555 configuration in some of my interrupters, that you can get a very better adjust of duty cycle (with diodes)
Fri Dec 05 2008, 05:10PM
You need clamping diodes on the primary of the GDT.
MRacerxdl
Sun Dec 07 2008, 12:10AM
I never used clamping diodes on the primary of the gdt, and is working fine.
Why I should use?
Avi
Sun Dec 07 2008, 12:26PM
Please note, the IGBT must be rated at double the input voltage, because the supply is in series with the induced voltage created in the 'off' side.
Tue Dec 09 2008, 12:10PM
Mestre Racerxdl wrote ...
Why I should use?
If you use gate driver chips its OK without diodes (they are built in). If you use bipolar transistors for driving the GDT, you must use diodes.
aonomus
Tue Dec 09 2008, 06:56PM
Gate driver chips internally have a halfbridge, and each MOSFET has its own diode by its own nature.
Dylan
Mon Dec 22 2008, 06:02AM
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
aonomus wrote ...
The TI UCC series of drivers seems more robust in this respect (not needing clamping diodes), but in my experience the Microchip TCxxxx series are easy to kill without them.
Anyway, nice work NNO2 , we all like to see new ways to build things!
