  • Guests: 63
Arcing from secondary to strike rail
Crimson Rain
Mon Dec 01 2008, 01:20AM Print
Crimson Rain Registered Member #1745 Joined: Wed Oct 08 2008, 12:29AM
How many coats of varnish should there be on the secondary coil to prevent this? Im using a 450W transformer so you know how much power Im using. Thanks!
Mon Dec 01 2008, 02:23AM
I used three coats. Do you have a toroid on top. If I am correct, the toroid sets up a field that helps prevent arcing.
Crimson Rain
Mon Dec 01 2008, 02:44AM
Yeah, theres a toroid on top. 3"x12" And theres also arcing along the secondary as well, which I know is bad >_<
teslacoolguy
Mon Dec 01 2008, 02:55AM
Those are racing arcs. Usually to much coupling causes that or to little varnish. How many coats of varnish is on the coil and how long is it between the uppermost primary turn and the lowest secondary turn? Also how far apart is the primary spaced from the secondary. Those measurements can determine the coupling but generally you want it around 0.13
Mon Dec 01 2008, 02:56AM
Crimson Rain wrote ...
You need to change coupling then. Coupling will fix it all. Just raise or lower the secondary to get the primary to be at the right level. Just a small change will change alot. Just use something quite thin and raise or lower until you get best performance.
Crimson Rain
Mon Dec 01 2008, 04:08AM
Thanks a lot for the suggestions guys. Ill let you know how things go =)
Dr. Drone
Mon Dec 01 2008, 04:16AM
shades
Mon Dec 01 2008, 03:04PM
To easily find the "correct" coupling and tune the tesla coil, use Link2
Tue Dec 02 2008, 03:07AM
It is in my experience that coatings will not stop these sparks, but will help protect your coil when they do occur. I really like using layers of epoxy coating (envirotex, ultra-glow, or even your typical 5 minute epoxy for little coils) that are so thick that the spark current tends to spread out over the surface and dissipate any localized heating that would cause the coating to fail. Thin varnish coatings seem to punch right through damaging the winding. But coatings are not the cure for the problem! As mentioned before, raise your secondary up some...
Other good fixes include making your primary have less sharp points. You can do this by placing a sheet of thick plastic (1/4" works well) over the primary. The plastic, having a higher dielectric constant, serves to spread out the e-field around the primary so that the primary looks more like a smooth flat surface, and this tends to keep corona from forming. This has worked wonders in many cases, but ive also seen this fail when condensation built up on the plastic.
