  • Guests: 78
Banana Man (41)
TheAnomaly (13)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Lowering Temperature
Dragon64
Sun Nov 30 2008, 05:32PM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
Well, I need a very cold condition to condense a liquid in my distilation apparatus.
In order to achive this, I have to find a way to lower the temperature dramatically while using common household items. I have thought of using dry ice with acetone but didn't have any dry ice. I also thought of using ammonium nitrate in water but was not practical for many design reasons.
Is there another way to make a very cold object using household material?
PS. Gramham condenser would not work.
Sun Nov 30 2008, 05:51PM
How cold?
Can't you just put the assembly in a freezer? Or if you are really feeling adventurous you could pull the cooling coil out of a bar refrigerator and build a smaller coldbox for it to cool your apparatus.
Backyard Skunkworks
Sun Nov 30 2008, 06:07PM
Magnesium Dichloride is a common ice melting salt, I've seen a huge bag (50lbs?) at costco for something like $17. It will give you a solution down to -25F/-32C/241K when melting ice.
rp181
Sun Nov 30 2008, 08:38PM
how about a couple TEC's?
Dragon64
Sun Nov 30 2008, 10:56PM
Yes, I had thought of using the refridgerator coil as a condenser but I don't any. Same with using the TEC. For now, I will use the salt and ice method.
I need cooling to about -50ºC
