  • Guests: 40
Bert (78)
MRacerxdl (34)
Alebaba (33)
kawenlong (37)
PeterJP (49)
11/09 Ragnarok (37)
11/09 Aleph (41)
11/10 hvscrapper (41)
Silly SCR question
David.Lightman
Fri Nov 28 2008, 05:28PM
David.Lightman Registered Member #1327 Joined: Mon Feb 18 2008, 12:13AM
I never thought to use a battery. I have an extensive circuit using the the supply voltage, transforming it down, then converting it to 12vdc. It never occurred to me to simply use a battery. What the h3ll was I thinking...... D.L
Killa-X
Sat Nov 29 2008, 01:54AM
buzzer wrote ...
I tried to buy an SCR gate drive from the largest manufacturer of gate drives in the US. The engineer for that company said they did not make a drive for my applicaion, "just anode fire it from the capcitor bank". I discharge the caps at 200V with a 470 ohm resistor in series to the gate. It works fine. The engineer said he did not think the 9V battery would properly fire the SCR.
Have you try Digikey? I got my 800V 50Amp rated one there, and I've used it with 6 of my 400V 470 uf capacitors and it works great. I also got my 1000V 6Amp diodes there xD
buzzer
Sat Nov 29 2008, 03:55AM
buzzer Registered Member #680 Joined: Fri May 04 2007, 03:20PM
Killa-x,
I was talking about a gate drive. Is your reply referring to a gate drive?
Turkey9
Sat Nov 29 2008, 05:36AM
You can sample some MOSFET drivers from Texas Instrument that work very well to drive an scr... the UCC37322 can give 9 amp pulses and is plenty fast enough. TI is a great place, you can sample the parts and they will send then FEDEX for free. Just use discretion when sampling cheesey !
rp181
Sat Nov 29 2008, 04:34PM
Commercial gate drives Use a different method. Rather than giving a direct pulse, they flat line, then ramp up at ~5v/us to ~10x the rated gate voltage, peak for a certain time, ramp back down, flat line, and finely go to zero. These methods maximize di/dt capability.
buzzer
Mon Dec 01 2008, 04:16AM
I trigger the gate from the capacitor bank charged to 200V with 470 ohm resistor in series. When the engineer told me to trigger the gate this way, I asked him if that was too many volts. He said no, "dont worry about the volts, the current is what tiggers the gate". Does this sound correct?
rp181
Mon Dec 01 2008, 04:25AM
The SCR has a silicon layer that triggers it. The silicon is not a dielectric, so it shouldnt break down under around 20v. Current is what triggers it, but to much voltage, you will ruin the SCR, and just get a nice beefy wire :).
I think the 470ohm resistor will provide enough of a voltage drop, and the current draw will be ~.4 Amps. It will trigger, but not at the best efficiency. Look at the datasheet for the triggering waveform.
buzzer
Mon Dec 01 2008, 05:10AM
Without getting too complicated, what would be a more efficient setup. I looked at the data sheet but did not really understand it. Is a battery and resistor better? My electronics knowledge is very limited, any help is greatly appreciated.
rp181
Mon Dec 01 2008, 03:15PM
as far as i know, a driver is the only "simple" wave to achieve that waveform.
