  • Guests: 58
Bridge feeding
ben106
Wed Nov 26 2008, 09:52AM Print
ben106 Registered Member #1374 Joined: Tue Mar 04 2008, 04:14PM
Hi,
I'm trying to build a SSTC. I saw that some people directly fed the half or full bridge (mosfets) with rectified (half or full wave) mains.
My question is : will this be able to feed the tesla coil at about 300-400 kHz ? Because I tried someting similar (with induction heating) and had the impression that mains is not able to follow that frequency (because of inductance), and it worked a lot better (it was not just the effect of a higher DC voltage because of the filtering) when I placed some smoothing film capacitors across the bridge, that are good at these frequencies.
Ben
LithiumLord
Wed Nov 26 2008, 11:45AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Independant of frequency, you need to install both film caps as brudge bypass for every case and some smoothing caps for the case you don't need the 50/100Hz modulation you'll get in a system fed by unsmoothed half- and fullwave rectified mains.
ben106
Wed Nov 26 2008, 11:52AM
Thanks ! So I'll at least put some film caps, and try to understand a bit better decoupling
Thu Nov 27 2008, 12:30AM
Decoupling caps do just as their name suggests: decouple the system from the line inductance feeding it. They may need to be fairly large if there is no DC bulk storage (like a big electrolytic). Several uF for a SSTC for sure.
