  • Guests: 38
Elliott (35)
Gratitude (40)
Swraka (37)
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
Musical Tesla Coil
cduma
Mon Nov 24 2008, 09:47PM Print
What is the best way to get a spark gap coil to play music?
My idea is to place a bank of 2n3055's on the primary side of the neon sign transformer and feed it with an audio signal.
What are the limations of musical tesla coils?
MRacerxdl
Mon Nov 24 2008, 09:52PM
It wont work, the modulation needs to be at frequency or amplitude modulation at the tesla coil fres, not from transformer. Changing the voltage from the transformer only will cause some nasty things with the spark gap, like it wont fire for the set tap.
I never see any SGTC's with audio modulation, I think there isnt a good way to do it, and the sstc's works very fine.
I hope I can help
Tue Nov 25 2008, 01:16AM
Mestre Racerxdl wrote ...
I hope I can help
Actually, it can work. In fact, Tesla himself was the first to audio modulate a Tesla coil about 100 years ago and also has a patent on it.
However, that said, the only modulation you'll get out of it is pulse modulation of the system itself. Basically, the modulation must be done at the spark gap or rather in place of it. Not sure of the specifics of how Tesla did it, but the best way is
to get a high voltage switch and modulate the switch, similar to how DRSSTCs are audio modulated. However, easier said than done.
Your best shot is the following:
1. PlasmaSonic - PWM modulation of a solid state coil - near perfect audio modulation and audio reproduction
2. Xenosonic - PRF modulation for DRSSTC type solid state coils
Details and schematics are available for both at:
TheBoozer
Wed Nov 26 2008, 12:16AM
So, hypothetically, if one was to mount a spark gap electrode to a voice coil servo, like a large speaker and PWM the servo..... Would modulating the spark gap voltage breakdown as such really create decent tones? I'm curious, but not ambitious to attempt it myself.
LithiumLord
Wed Nov 26 2008, 01:00AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Ever heared of motor drivers? Those babes can deliver quite a punch and have an MC core, so you can fire up a sequence of accelerations/decelerations through them and, probably via some mods, probably by means of a separate MC, cause the system to switch the power supply on and off when needed... theoretically :)
Fri Nov 28 2008, 10:47PM
I think a triggered spark gap is the way to go (if you must do spark gaps) along with DC reso-charging. Your max BPS is limited by the DC supply then, but this is true of solid state coils too.
Fri Nov 28 2008, 11:18PM
Yes, use a dc tesla coil, and a capacitor that is small enough to fire perhaps 20khz, give or take. Reason is, you must have the spark gap firing and the correct frequency to sound correct, and audio can be as high as 20khz.
