  • Guests: 52
More trippy stuff :D
LithiumLord
Sun Nov 23 2008, 03:42PM Print
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Well, just recalled I didn't post this one here. The thingie I call the warpdrive simulator, actiually a nice little exe drawing an infinite tunnel. No trojans etc, no need to even bother checking for ones - I wrote this one from scratch (VB6 lol). Requires a DX7 full hardware support (doubt anyone has no, still mentioned however). Don't forget to try holding spacebar in-flight - makes really spooky things. If anyone won't figure that out, ESC ends the program :)
The tunnel model is generated randomly on each startup.
Screenshot Link2
tom
Sun Nov 23 2008, 03:47PM
tom Registered Member #1823 Joined: Sun Nov 23 2008, 01:23PM
Very nice... Hurts my eyes if I stair at it long enough amazed
Sun Nov 23 2008, 08:05PM
I liked it :)
I also used to make graphics rendering programs in Pascal programming language, for fun.
I even made a program which displayed a random rotating 3D Lissajous curve, using just a basic 2D library ("VESA")...
Sun Nov 23 2008, 08:29PM
Well, here is a trippy video from youtube:
That is very addictive(at least t to me). I couldn't stop watching it! At 13 seconds it seems like something has gone horribly wrong :P. I watched it like 200 time in two days.
LithiumLord
Mon Nov 24 2008, 12:40AM
Dr. Kilovolt wrote ...
I liked it :)
Heh, same here, but on QB4.5 :D Best ones were animated deformable 3D surfaces (wireframes of course), a small attempt on a flightsim (made no input - so steering was just a random sine-based function - but it used an "infinite" surface with the startup generation routine pretty alike to the one used here) and a vertex shader attempt - you could position a wireframe surface, then upon a key press it was rendered as a solid plane split in 256 projected squares and a light tracer routine was calculating lighting for each one casted by two lightsources along with speculars, while the palette set function was modifying the palette so it looked like an actual realtime per-face lighting, excepting the surface remaining static to the camera. Bad I lost all my old sources, however will recode some just for fun - made a remake of that flightsim already - this time on VB with pure GDI - was called to the office for some maintanence and had a lot of free time there.
Wolfram
Mon Nov 24 2008, 07:52AM
Trippy algorithmically generated graphics in hardware: Link2
Anders M.
Andyman
Tue Nov 25 2008, 09:19AM
Would I be able to get that as my screen saver? And in 1024x768 so that it bypasses the initial menu.
