  • Guests: 39
Help with DRSSTC
MRacerxdl
Fri Nov 21 2008, 11:05PM Print
Hi all,
After a few tests with my DRSSTC and the OCD, my IGBT's blowed up, but it was strange, because I limited it to 50A only. and the IGBT are for 200A Pulsed. IGBT's was cool when blowed.
Ok, I was see on the forum some people talking about the reverse diode, that in some TO247 have a low current. That IGBT that I use have a Reverse Diode with only 5.4A Capabilty, I think its too low. (SGTW30NC60WD)
So I get the version without the diode (STGW30NC60W), and now, what diode should I use ? I was thinking about use it for 150A .
Other thing, I have two MiniBrick mosfets (STE45NK80ZD) with 45A 800V and 600W of dissipation. It has a 180A Pulsed current, the diode and the mosfet. It is a good think to use on a DRSSTC? Or do I keep it with a big ass SSTC?
Thanks!
Tom540
Mon Nov 24 2008, 06:30PM
Tom540 Banned on 3/17/2009.
Just add your own reverse diode in parallel with the igbt drain and source.
MRacerxdl
Mon Nov 24 2008, 09:30PM
Yeah, that I was thiking about, but what diode I should use? I mean, what current it needs to handle? Something like Primary Current?
Thu Nov 27 2008, 12:32AM
It will see the same peak current as the primary circuit does, but the duty cycle for the diodes is much less than the IGBTs.
I suspect a 30-40A ultrafast diode in a 247 package is plenty good. Diodes are hard to break.
