  • Guests: 37
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
Designing 2kW electromagnet
Dr. Slack
Mon Nov 24 2008, 09:50AM
More turns = greater resistive losses = more heat
No, do the math
Take a given coilform, so constant winding length per turn, constant total winding area, and constant volume = constant weight of copper wire. To simplify things, assuming the filling fraction is constant with wire diameter, as it's not a material but a practical factor, and very slowly varying at that.
Assume a number of turns N.
Winding length proportional to N
wire area proportional to 1/N
so resistance proportional to length/area or N^2
Power can be written P=I^2.R, so I=sqrt(P/R)
therefore I proportional to sqrt(P)/N
magnetic field is proportional to I.N, the Ns cancel to give sqrt(P)
I'll leave it as an exercise for the reader to show exactly how the constant of proportionality between field and sqrt(power) is related to the weight of copper used (hint, as spend on copper goes down, spend on energy goes up for a constant field, no surprises there then).
In answer to the question in first post, the best way to build a very strong electro-magnet is to use DC, an iron core, and then sufficient copper and power to saturate the iron. Once you are well into saturation, extra power is just pissing in the wind.
I recently helped my son with a physics project, building a small air-core electromagnet for linearity testing of a linear Hall element. I discovered that the 25mm dia, 25mm long bobbin would take 2watts continuous, but would take 200 watts for the few seconds required to take a reading for the same temperature rise. So if you can be disciplined enough to demonstrate your magnet 5 seconds on, 15 minutes off, you can use a very small coil to get the iron into saturation. Even a 30 second power pulse would allow you much greater power than continuous, and 30s would seem like continuous to your awestruck onlookers.
cduma
Mon Nov 24 2008, 09:41PM
cduma Registered Member #1822 Joined: Fri Nov 21 2008, 08:04PM
Wow! I am impressed by all of the responses. I took the primary from a microwave oven and wired it in series with a 60w bulb and ran 132vac from a variac through it and nothing happened. No reaction to iron or neodymium. When the primary is still attached to the iron core it makes a loud thump and then a 60hz hum when powered on but, still no reaction to iron objects. When exposed to neodymium the hum stops though.
aonomus
Tue Nov 25 2008, 02:01AM
Electromagnets don't work with AC, you need a unidirectional flow of current inorder to create a magnetic field. With AC all you get is a magnetic field that flips back and forth at 60hz...
Tue Nov 25 2008, 02:32AM
aonomus wrote ...
No, electromagnets work just fine with AC. Surely you're aware of ac-driven solenoids and doorbells and the like. An oscillating magnetic field attracts iron very much like a steady magnetic field.
