  • Guests: 115
Fuel Rod Cannon (coilgun)
KLH
Thu Nov 20 2008, 08:47PM Print
KLH Registered Member #1819 Joined: Thu Nov 20 2008, 04:05PM
I have decided to post ideas and plans for my first coilgun.
Current Planned Specs:
Storage Energy - 1903.5 Joules (450V on 18800uF)
Muzzle Energy - 285.525 Joules
Efficiency - 15%
Projectile Diameter - 3.8 cm
Projectile Length - 12.7 cm
Projectile Mass - 388 g
Projectile Material - Aluminum
Muzzle Velocity - 38.319 meters / second
Rate Of Fire - 15 rpm
Total Weight Of Coilgun- 13.6 kg
Goal Specs:
Muzzle Energy - 475.875 Joules
Efficiency - 25%
Projectile Length - 20 cm
Projectile Mass - 612.422 g
Muzzle Velocity - 39.421 meters / second
Rate Of Fire - 40 to 60 rpm
Total Weight Of Coilgun- 23.178 kg
The capacitor charging circuit is a 1500W to 1700W Push-Pull converter using a custom made 1:37 ratio transformer, or, as an alternative, a constant-current boost converter (both of my own design). Hopefully, either of these will be able to charge the capacitors fast enough to achieve the rates of fire that I have planned.
As stated above, the capacitor bank will consist of 4 capacitors (450V 4700uF) in parallel connected using bus bars.
The main power switching device will be an Ixys MCC162-16-io1 with an average gurrent of 160A and a peak current of about 6000A per SCR. The first one will actually switch the coil, and the second one acts as a protection diode (self-triggered SCR when forward voltage is applied).
The coil itself will be made of two layers of 96 turns with 48 turns per layer. This will have an inductance of about 100uH and a resistance of about 0.04 ohms.
The shunt circuit will be designed to absorb a full power discharge without a projectile, but hopefully this power dissipation capability will not be needed with a projectile inserted, because that would mean wasted power. It will consist of the second SCR in the MCC162-16-io1 wired as a protection diode to the dissipation circuit consisting of a capacitor and a resistor in parallel, but with an MOV between them. The capacitor will ramp up the voltage across the inductor so that either SCR's dV/dT rating will not be exceeded. After the voltage exceeds a certain level, the MOV will divert the rest of the inductor's stored energy to the resistor, where it will dissipate it as heat (as with most designs).
The entire circuit will be placed inside a metal casing made to look almost exactly like the Fuel Rod Cannon from Halo 2, shown below:
1227209519 1819 FT0 Fuel Rod Cannon
The coil and circuit will be magnetically shielded to prevent eddy current losses from occurring in the casing.
Comments and suggestions are highly appreciated, especially regarding the feasibility of the specs (in my opinion, both planned specs are achievable, but the goal specs will take much longer to achieve).
El_Roberto
Thu Nov 20 2008, 09:19PM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
Well the first problem I can see is that the projectile is made out of aluminium. Aluminium is not ferromagnetic so in a conventional coingun it would do nothing, unless you're planning to made an induction launcher rather than a coilgun? Also an efficiency of 15% is extremely generous for a coilgun Id say closer to 2% or 3% would be more realistic. And if it is infact a coilgun you want to make then id suggest you try a multistage one, this would make it more effective. Also 23kg is pretty heavy for a gun...(I think). I think your goal with rate of fire is good though, not many (None that I know of) have tried this with a high powered coilgun, Youll need extremely thick wire (8AWG?) and probably active coooling to prevent it from overheating as my coilgun (400j, 19AWG single coil) overheats after about 3 shots!
Edit: Also those Switches are only rated for 6000A peak I have estimated (Using the info given) that the peak current will be closer to 6160A.
big5824
Thu Nov 20 2008, 09:29PM
yea the highest efficiency i know of was 10%, and im not sure if i believe it...
youl probably get 3% tops
KLH
Thu Nov 20 2008, 10:33PM
El_Roberto wrote...
That is correct. I'm making a coilgun that uses induced magnetic fields to repel the projectile. I also might use copper as a projectile material as it has a lower resistance.
El_Roberto wrote...
The following is just my pure, theoretical logic (as is most of my thinking), so if you see something horribly wrong with it, please comment.
PowerLabs has made a single stage coilgun that achieves a muzzle energy of 360J with an efficiency of 12%, so it is achievable in my opinion. The reason why I predict higher efficiency figures is because I don't have to worry about things such as suckback (since it is being repelled) and projectile saturation (of course, up to a point where the projectile melts due to resistive losses).
Also, AC induction motors are very efficient (I think >90%) and they work on the same repulsive principles as an induction coilgun. Both of these devices are basically transformers with mobile secondaries, and transformers are also efficient.
El_Roberto wrote...
Thanks for mentioning... I was thinking of using 10 AWG wire, but I'll look into 8 AWG wire and see how much of a benefit (in terms of dissipation) it offers. PowerLabs' single stage coilgun uses 10 AWG wire hooked up to a 3000J capacitor bank with fairly good results.
El_Roberto wrote...
That's very true... smile
The military probably wouldn't adopt this as a weapon, considering the fact that they thought the M60 machine gun (~25 lbs, I think) was heavy.
I might still make the final coilgun like this so it will have the same weight as the real Halo Fuel Rod Cannon. This comes with a nice melee attack... smile
El_Roberto wrote...
Thanks for pointing that out. I have another dual-SCR by Semikron very similar to the Ixys dual-SCR, and I accidentally used its peak current specification instead of the one from Ixys. The peak current rating for an 8.3 ms pulse using the MCC162-16-io1 is actually 6400A.
What I am wondering now is if that is a big enough margin.
Thanks for your suggestions, as this is my first coilgun.
Firefox
Thu Nov 20 2008, 11:42PM
The peak current that an SCR can handle goes up as the pulse length goes down. If you have an inductance meter with the appropriate range, you can use this simulator Link2 to find your pulse shape and length. If your pulse is shorter than 8.3ms, but only a little bit higher than the pulse rating of the SCR, then you should be ok.
rp181
Fri Nov 21 2008, 12:42AM
the pulse rating goes up exponentially.
Backyard Skunkworks
Fri Nov 21 2008, 01:34AM
I think you might be able to approch those insane efficiencies with cryogenic cooling. Someone tried that a couple years back and got some good results but it never took off due to the obvious need for a cryogen.
Fri Nov 21 2008, 02:10PM
I must say it's an ambitious project! I'd like to see how it turns out. 15% with a single stage sounds like a long shot to me, but we'll see how it goes. You have better chances at greater efficiency with multi stage designs.
OZZY
Fri Nov 21 2008, 06:17PM
OZZY Registered Member #511 Joined: Sat Feb 10 2007, 11:36AM
Hi killah573 and welcome to the forum.
I think this is an excellent project and I look forward to seeing how it turns out. I think the overall aims and specs are perfectly reasonable, here are my thaughts so far.
1. The efficiency is a bit optimistic, I would use 15% as the ultimate goal. Your first prototype could be 0.1% to 10% depending on how successful the design is.
2. That SCR is probably capable of switching a 1.9KJ bank but it will depend on the total resistance of the circuit not the peak current.
3. An induction coilgun needs high current and high dI/dt, at 450V and 18,800uF a 100uH coil is way too much, the pulse will be too long and the peak current too low. For this bank you want 5 to 10uH this gives you 10 to 20 turns of 10AWG wire. If you put all the capacitors in series for 1800V and 1175uF the bank will be better matched to a 100uH coil.
4. Single stage induction launchers based on the pancake coil geometry with the armature as a flat plate are generally successful and can be efficient. Single stage induction launchers with a solenoid coil and rod armature are spectacularly un-successful. I have a theory as to why this is the case, the force on the armature is proportional to the inductance gradiant, or more correctly the gradient of the mutual inductance between the coil and armature dM/dx. In the case of the pancake coil when the plate is close to the coil the gradient is huge but drops rapidly with distance, so this design can generate a very large force but only over a short distance. The solenoid coil has a much lower gradient but can produce a force over the full length of the coil. If you use a low inductance coil the short pulse will produce a force but the pulse will be over before the armature has moved much, force x distance = kinetic energy so the efficiency will be low. If you use a high inductance coil the long pulse will produce virtually no force at all.
Read this PLIM and this Induction coilgun
I hope this is of some help. Ozzy
Fri Nov 21 2008, 07:22PM
You need to put some of those caps in parallel. Have at least 800 volts, preferably more for high peak current and a faster discharge.
