  • Guests: 62
01/13 si2030 (62)
Building a power supply for a small CO2 laser tube?
lpfthings
Wed Nov 19 2008, 12:33PM Print
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
I have a small CO2 laser tube here, and need to get a power supply for it. Its operating spec's are 13kV, 18ma. The trigger voltage is 20kV, but I am just going to use something like a bbq ignitor for that. Apparently it is a DC tube. Anyone know how I could get 13kV @ about 18ma?
Flyback would be easy, but I don't think they can source enough current ....
Thanks
Wed Nov 19 2008, 01:35PM
If you can find one, an old NST of 5kV-0-5kV - such as the British Tunewell type which has an easily removable centre-tap - would provide you with 14kV once it was rectified.
Older non-electronic American-made NSTs might also be suitable. There are plenty of NST enthusiasts on this site to ask! cheesey
Dago
Wed Nov 19 2008, 02:43PM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
lpfthings wrote ...
Thanks
CO2 lasers usually do not require an igniter.
Shaun
Wed Nov 19 2008, 06:30PM
I would go with rectified NST; I have a small tube of similar specs and it works fine.
As for ignition voltage, that just means it should produce 20kV open circuit, which will then drop to 13kV under load.
You really don't need to worry about tube voltage, just put a cheap ammeter in series with the tube to make sure the current stays in check. After all, Ohm's law will keep the voltage across the tube exactly where it should be, as long as current and temperature stay in operating range.
Wed Nov 19 2008, 07:39PM
If you can get an old and hefty AC bare-wire TV transformer, it should be able to source the current you need. Of course you need to use a rectifier, preferrably a fullwave one...
I used one in my demo Jacobs ladder, it operated approx. 500W peak for 6 hours and survived...
Edit: It is easy to wind your own if you have the core (preferrably a larger one).
