  • Guests: 34
01/13 si2030 (62)
Musical drum-tracking hardware (or software?)
LithiumLord
Tue Nov 18 2008, 10:30AM Print
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Well, I have really no idea where to ask this so I ask this here :)
The question is - I planned to use something as a strobe or tesla coil driver to make it synchronize with music playing (not MIDI of course :) ). Before I just used to run my own program that reads spectrum data from WinAmp, takes a short part of (two in fact - one for one-shot, one for burst) it and uses it as an integrated intensity to detect fast jumps over the peak level (that falls off slowly - like WinAmp's dashes across the level meter, but coded separately to run on different ranges). That works, sometimes sucky, sometimes well - but I decided a better solution to be made. Now I'm stuck lol. The new software one was inspired by the Audiosurf game, that one really makes sence as it's beat tracking capability is awesome. However I have no idea how to code it :D
The other idea was a hardware one - you run the signal through a resonance filter, then just rectify it with a diode bridge and feed to a cap via a shunt, the cap itself is shunted by a falloff resistor. Therefore, whenever you have a fast signal rise above the constantly falling peak level, the voltage on the charging shunt hits a high value so you can track it with a comparator and use it's output as a strobe to fire a coil or a strobelight perfectly on the beats.. in theory :) In reality I have no idea if this would work in any good way. So, anyone tried alike stuff?
Tue Nov 18 2008, 10:37AM
The time-honoured method, dating from the invention of disco lights in the 70s, is a low-pass filter feeding into a rectifier and comparator. The peak-to-average ratio method that you described is a nice improvement on the plain comparator.
For more up-to-date methods, try searching the music-dsp email list archives for "beat detection". Link2 They have lots of discussion and example source code.
LithiumLord
Wed Nov 19 2008, 12:32AM
Yaaay! Thanks a lot! Seems I pretty like this one: Link2
It's pretty easy to code so I'll try making something alike in ASM, also it's short so wouldn't be tough to run it on an AVR hardware. So looks like I'll try it out on a test board.
LithiumLord
Tue Nov 25 2008, 01:58AM
sry for dblposring, but I just have to tell this for the case anyone wants to make alike stuff.
This one needs a unipolar input so it's best to integrate it into a TDA-based amp so you can use it both for coil drive and high-level headphone output to be unable to hear actual coil discharge sounds, however you can add a diode bridge instead of the shottky diode, a level shifter would go as well. The base bypass cap is required to reject any noise, the ADC pin was drawn just as a leftover of older research - actually this needs just a Schmitt trigger or a comparator. It's 5am here atm, so I had no time to assemble this nor to add the proper input jack and firmware upgrade into the coil's AVR - but the test circuit with a LED worked out perfectly - it was even capable of accurate tracking of the blastbeat parts (actually that's what I started it for).
