  • Guests: 52
Anyone use this flyback driver?
Sun Nov 16 2008, 07:54PM Print
Well, i am not going to try it because i do not have the stuff, but it looks like it is a simple PWM oscillator and two transistors, and a snubber. The two outputs are 180 degrees out of phase i guess, to work like a push-pull, on the PWM ic.
Just thought i would bring it up, and see if it would be a good lower powered flyback driver for beginners, and it would be rather cheap. I have a ZVS, i just need to get it to pull more current, so i don't need to make this, but i am sure someone out there may appreciate this.
teslacoolguy
Sun Nov 16 2008, 08:06PM
That looks like it is a type of royer oscillator because the bridge section is designed similar to the very popular zvs driver.
Sun Nov 16 2008, 08:48PM
That is just a generic half bridge driver (well, half bridge isn't really the word for it, but it is very common to use a center tapped primary like that), and note the the circuit does note operate like a mazzilli flyback driver or even like a normal royer, but is just a fixed frequency driver like you would find in any 'normal' smps. If you get it running at the resonant frequency of the transformer it would probably work quite well at making very high voltages, especially if you add the extra CW multiplier
Sun Nov 16 2008, 10:11PM
That's a push-pull driver, not very efficient (you can find out yourself, I already did smile )
Sun Nov 16 2008, 11:24PM
Dr. Kilovolt wrote ...
Ahhh, so it was a push pull! That is what myke told me, casue at first i though halfbridge. I was actually looking at your thread about the two switching topologies, and thought that it would have problems.
