  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
FATBOY obtains a Face Lift!
Dr. Drone
Sat Nov 15 2008, 06:27PM Print
shades
Sat Nov 15 2008, 06:34PM
Woah! That looks spectacular! I got the same polyurethane, i just need to make a secondary and something to turn it while varnishing!
That sure looks like alot of work and time though, but i have more time than i know what to do with!
coillah
Sat Nov 15 2008, 08:16PM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
very nice! I need to do this...
Sat Nov 15 2008, 09:22PM
How exactly do you do it? You sand it down with like 1000 grit wet/dry sandpaper every few(or every) coats? It sure looks incredible, and i am sure that it will last a long time, and protect from scratches.
Dr. Drone
Sat Nov 15 2008, 10:40PM
shades
Sat Nov 15 2008, 11:13PM
Dr. Spark wrote ...
Arcstarter wrote ...
Get a good base of 20 coats. This will ensure you do not sand into the wire. Then sand lighly with 320-grit sandpaper. Apply three coats and let dry for a few days until you can stick your fingernail into paint with no mark. Sand with 400-grit sandpaper, apply three to five coats, and let dry a week. Then the fun with Wet/DRY Black sandpaper. Put a little water on coil and sand your brains out. Apply three to five coats and sand again with 800-grit WET/DRY Black sandpaper. Let dry a week, say your prays and apply last coat.
Yes, it takes time but have a few projects running and just sand a little each night and jump on another project (Quad VTTC)
Cheers,
Ch
I am now copying and pasting into wordpad and saving it :P. I dont care how long it takes, a coil that can look like yours, is soooo worth the time(which i have plenty of).
Thanks, now i am going to get some more 24 gauge wire and make a big coil!
Firefox
Sat Nov 15 2008, 11:24PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
Beautiful work, as always, Dr. Spark. Looks like you dipped the thing in glass.
As for music, how about 'Cliffs of Dover,' it seems pretty good for MIDI music.
Probably not MIDI friendly, but the Dropkick Murphys' 'Tessie' has a certainly irony to it, if only in name. 'Lightning Does the Work,' does as well, but it is less MIDI friendly even than Tessie.
Sat Nov 15 2008, 11:44PM
The coil looks absolutely sweet. I'm thinking of putting some more layers of varnish on my coil. But can I ask you how long it took to get that far with so many layers.
Dr. Drone
Sun Nov 16 2008, 01:20AM
shades
Firefox
Sun Nov 16 2008, 03:22AM
Sounds like it will work great, Dr. Spark. Can't wait to hear your coils rocking out. cheesey
