  • Guests: 43
What to do with...
Zenador
Thu Nov 13 2008, 03:46PM Print
Zenador Registered Member #1733 Joined: Thu Oct 02 2008, 03:17PM
I have 2 issues.
One, I have parts I don't know what to do with.
2x vacuum motors. different sizes, both work. Came out of working but useless stick vacuums. One could go into a
sucker SGTC, the other I dunno.
A 5kV 30mA NST. I could build another table-top TC, but I have one already. Suggestions?
Small MOT. Don't have the ratings off-hand.
20 camera flash boards. I've made 2 coils from these parts, but I have 20 intact boards left. I was thinking a cap-bank charger for a mini rail gun and mini coil gun. I'll still have many boards left over.
My second issue is my girlfriend (whom I live with) needs a hobby. She gets bored easily, really easily if I'm in my workshop working on stuff. She feigns interest in my coils and other projects, so I have no hope in getting her to help. What do your wives/girlfriends do while you are working on your projects or otherwise engaged?
Thanks guys...
Z
Thu Nov 13 2008, 06:32PM
Well, you could make a sgtc with that single mot believe it or not. Just use a voltage quadrupler and a properly sized high voltage choke.
Steve connor has a very nice one, as seen above.
The thing i really like about those DC tesla coils is that the power supply is constant voltage, so you can use an asynchronous rotary spark gap without losing power output because it will not fire at too low voltages just because the cap is right in the middle of the sinewave. So, you can accurately change the bps without worrying about losing performance.
20 of those camera flash caps would make a decent coilgun or railgun or w/e you may use it for. I would highly recommend that you use bleeder/balancer resistors and make a few strings of a few caps and put the strings in parallel. Because that will have the same energy storage and all in parallel, but at a higher voltage. The higher the voltage compared to capacitance, the faster the discharge will be. You of course want a fast discharge, because if the discharge takes to long on a coilgun, the projectile will first be accelerated, and then decelerated, so you will lose efficiency with slower discharge. Also be sure to use a protection diode across the capacitor bank to stop a reverse charge, which is caused by the inductance in the wires, and coil. Of course, as you probably know, you do not want a polarized cap to be charged with wrong polarity.
Also, for just a bit of fun, you can use one of the vacuum motors for a rsg :P. A high speed one, but of course it would take time and money because you would need reduction gears/pulleys.
aonomus
Fri Nov 14 2008, 12:35AM
Do what the mythbusters did and build a miniature hovercraft...
Or alternatively stick your lips into the spinning fan blades inside the vacuum motor.
teslacoolguy
Fri Nov 14 2008, 01:31AM
aonomus wrote ...
That is an excellent idea*
* not responsible for any lip damage that could result wink
Backyard Skunkworks
Fri Nov 14 2008, 02:05AM
You can make a fun gun with vacuum cleaner motors. Use them to drive two wheels that almost touch, and then feed a projectile in.
Fri Nov 14 2008, 03:45AM
Backyard Skunkworks wrote ...
That would be fun, but dont you think 15k rpm would be a little much for anything that has good enough friction? If you where going to use something like a small metal rod, you would need like a pneumatic tire to allow for it to 'warp' to the size of the projectile, while still tight around it, and you would need to use something like rubber for plenty of friction. So what i propose is just use a large pneumatic tire and use some reduction gears, because, i mean come on, at 15k rpm there would be a s$#t ton of centrifugal force and it would rip it apart.
Fri Nov 14 2008, 11:42AM
Something like this... Link2
Zenador
Fri Nov 14 2008, 02:20PM
Thanks guys.. I watched the MythBusters where Adam put his lip to the blade. Not intelligent. The projectile launcher is nothing more than a mini batting cage ball launcher.
I think I figured out my next project. I was reading up on Plasma speakers. Looks so sweet. The only thing in my way at the moment is finishing my boost converter. I etched a board for it, mounted everything, hooked it up, and proceeded to fry 2 inductors. The first was too small and fried instantly, the second one lasted about 5 minutes before smoking.
While the smoke is disappointing, it's still kind of neat. And small inductors make a really neat sound when they blow.
Z
