  • Guests: 29
recursive question again
scrooch
Wed Nov 12 2008, 07:15AM Print
scrooch Registered Member #908 Joined: Wed Jul 18 2007, 05:53AM
Public void foo(StackInterface s)
if(!s.isEmpty())
Object o=s.pop();
foo(s);
s.push(o);
System.out.print(o);
can someone explain how the code executes once it gets to the statement "foo(s)"
this is really confusing for me
and can you do it with an example
say the the stack contains the items 3,2,1
top to bottom.(i.e stack top is "3")
thanks in advance
Wed Nov 12 2008, 10:36AM
For more information on recursion, see Link2
scrooch
Wed Nov 12 2008, 11:32AM
Steve McConner wrote ...
lol man thats as far as i understand
Bjørn
Wed Nov 12 2008, 10:24PM
It will push any variables on the system stack, then call foo like normal. When foo returns it will pull the variables off the system stack and continue where it left off, like it would do for any other call.
So during the 3 first iterations it will move the 3 items on the s stack onto the system stack.
When it has pulled 1 off the s stack it will call foo that will just return because the stack is now empty, then it will push 1 bak onto the s stack and so on....
I recommend running code like this line by line in a simulator or debugger because it can get really confusing to see what happens.
