  • Guests: 78
My new tesla coil toy is done :)
Staci
Mon Nov 10 2008, 10:32PM Print
Staci Registered Member #1741 Joined: Sat Oct 04 2008, 02:45AM
I couldn't set the PFC to higher than 215VDC out because it would shock me when I hold it.
Here's a youtube video too:
Here's an early picture of the inside:
Now it has a Faraday cage around power electronics module because the PFC boost regulator is digitally controlled
TheBoozer
Mon Nov 10 2008, 11:01PM
That was downright awesome... Any specs???
Dylan
Mon Nov 10 2008, 11:10PM
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
HeheheheHAhhahA , thats excellent!!
Nice one!
cheesey
Mon Nov 10 2008, 11:17PM
If you aren't grounding the coil through an external ground wire, but rather just through the grip you are passing considerably amounts of RF through yourself and that is generally bad. If you are grounding it then all is probably well :)
That is a sweet toy none the less amazed
Staci
Mon Nov 10 2008, 11:33PM
ground comes from earth - in the line cord. It's painfully obvious when I find an outlet where the ground pin is not hooked up...
Specs:
PIC18F2658 based digital PFC in rCCM mode, also controls LEDs, sound effect, and graphics LCD.
Power is settable from PFC reference and burst length - I went from 4046 PLL to all Steve Ward's design because it looked bullet-proof. That's about 110 watts RMS as measured with a Yokogawa PZ4000, pf of 0.98
It shoots 16" or so to earth, and makes a nice hot plume in free air... Any higher voltage on the PFC output and it will arc back to me.
Thanks guys :)
Tue Nov 11 2008, 12:31AM
Very nice! I tried to comment on youtube but it wouldn't let me :P.
Coronafix
Tue Nov 11 2008, 01:04AM
That is super nice!! Good job!
teslacoolguy
Tue Nov 11 2008, 01:13AM
Hahahaha that's just cool. The graphic lcd adds the final touch to it wink so when is that thing going to hit the market in the wall mart toys section cheesey
ragnar
Tue Nov 11 2008, 02:01AM
Hot! Looks durable and I admire the primary insulation. You might be able to get longer sparks without getting 'bitten' if you use a topload other than toroidal -- it encourages discharges out the sides.
Myke
Tue Nov 11 2008, 02:29AM
Hah, That's so cool. amazed (don't know what else to say)
