  • Guests: 56
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
UCC37321 and UCC37322 in Steve's "Mini SSTC" and other drivers.
J. Aaron Holmes
Sun Nov 09 2008, 08:30PM Print
Hello, coilers:
I've decided, at long last, to build a conventional SSTC. My driver is more or less a rip-off of Steve Ward's "Mini SSTC" driver, with a few extra protective measure sprinkled on top (which are, in turn, ripped off from a number of other people's designs wink) However, I just realized that I don't undestand why Steve's design uses both a non-inverting and an inverting driver when there's an inverter IC sitting right there too (7414). Any takers? I'm tempted just to use two 37322's and derive the input for one from after both inverters and the input for the other from between them. This would seem nicer, because then there is only one kind of driver IC being used here, and I don't have to stockpile both kinds.
Perhaps some seasoned SSTC'er will tell me what nuance of the -21/-22 pair makes it better?
Cheers,
Aaron, N7OE
Dylan
Sun Nov 09 2008, 10:02PM
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
The only benefit is that both are driven at EXACTLY the same time, adding another inverter, or taking one drive from an earlier inverter will add some ns delay.
This is not a problem in my experience, and in fact there are often timing/drive differences in the inverting / non inverting gate drivers anyway.
So you should be fine, but thats the reasoning behind it.
Sun Nov 09 2008, 10:32PM
If i understand the question right(which i highly doubt :P) The inverting and non inverting are both used because it gives 24 volts(assuming you use 12 volts input) through the gdt. This is good for making sure the mosfets turn completely on. I am probably wrong about something here, but i know that the inverting and non inverting are used for high gdt voltage.
Ken M.
Sun Nov 09 2008, 10:45PM
The way I understand is like arc starter said the are tired together so that when the signal flips it acts like a 24v square wave but the reason for not using an inverter off the 7414 is because the uccs are HIGH current where as the 7414 is a few ma, which helps drive the gdt better then just using one of the spare inverters.
Sun Nov 09 2008, 10:48PM
I haven't checked the datasheets to confirm, but I doubt the delay in the inverting UCC and the 7414 buffer are much different. And you'll most likely be running a coil with fres of 200kHz??, in which case 15ns of delay is negligible. Unless your coil is HF and the delay difference may cause problems, you're clear to use the 7414 as the inverter.
J. Aaron Holmes
Sun Nov 09 2008, 11:01PM
Arcstarter wrote ...
Sure, it makes perfect sense. However as I understand, the inverting IC is just like the non-inverting one except that it has an Schmitt trigger inverter (i.e., like in the 7414) integrated into it. I'm just wondering why that can't be factored out. You'd still get the 24Vpp.
Ken M. wrote ...
I was talking about inverting the *input* to the *UCC*, and certainly wasn't suggesting feeding the GDT from a 7414 suprised No siree! That would indeed not work.
Dylan wrote ...
Uzzors wrote ...
Thanks, folks; that's what I was hoping to hear. Yeah, 200kHz is in the neighborhood. I probably should have spent some more time with the datasheets myself before asking tongue
Cheers,
Aaron, N7OE
Mon Nov 10 2008, 02:11AM
Sure, you could do it that way, no difference really.
J. Aaron Holmes
Mon Nov 10 2008, 02:22AM
Steve Ward wrote ...
Groovy, thanks, Steve. Just proceeding on the assumption that I'll be less likely to mess things up if I have fewer different kinds of building blocks; harder for me to get things backwards that way! tongue
Cheers,
Aaron, N7OE
Tom540
Mon Nov 10 2008, 04:47AM
Tom540 Banned on 3/17/2009.
Or you could use two ucc27425 drivers in parallel. I started using these becase theres only one type of driver to buy, they're cheaper and I can get away with only using one if need be on the same board. I just don't populate one driver.
