  • Guests: 31
Question about full wave rectification???
Plasmaarc452
Sun Nov 09 2008, 08:00PM Print
Plasmaarc452 Registered Member #1394 Joined: Sun Mar 16 2008, 06:18PM
I was wondering, can you do full wave rectification straight from the 115v AC wall plug to get 115 DC? Assuming I have diodes rated for the voltage and the current.
So far I have only done it with a small transformer, 115v AC in 6v AC out then I did full wave rectification to get 6v DC but I don't want to trip the breaker or mess up good diodes trying to hook it up to the wall if its not possible.
Billybobjoe
Sun Nov 09 2008, 08:21PM
Rectification is definitely possible from a wall outlet but you will actually get sqrt(2)x 120v = 170VDC out. What kind of load are you looking to run? Mains power is not current limited so you will need to be careful not to short anything and always limit the current to the ratings of you diodes and circuit breakers.
Myke
Sun Nov 09 2008, 08:43PM
You can rectify the line voltage but like Billybobjoe said, you don't want to short anything. Also you don't want to come into contact with any of the power leads because they are not isolated from the mains.
Sun Nov 09 2008, 09:40PM
If you use filtering caps after the rectifier, make sure you use some inrush current limiting or you can blow your diodes/switch or trip the breaker...
If you do not use any filtering then you'll indeed get a voltage with 120V DC RMS value, but it will have the 170V peaks.
Backyard Skunkworks
Mon Nov 10 2008, 03:21AM
I've had a lot of sucess with two AC "wall warts", one stepping 115VAC down to a low voltage and the other stepping it back up again. Then full wave rectification. I've use the output from a 230VAC wart full waved for cap charging. Using this method the current is limited quite well, however it is somewhat lossy. This can work really well if you need less than 20 watts and dont care about some power losses to the cores...
