  • Guests: 33
01/13 si2030 (62)
Help with ZVS driver..
jovica
Mon Nov 10 2008, 10:17AM
jovica Registered Member #1790 Joined: Fri Oct 31 2008, 10:10AM
Myke wrote ...
For a IH, I would suggest something else besides a ZVS flyback driver.
Why ?
A ZVS flyback driver is a great starter in induction heaters, just make a 5+5 turns 5mm2 + work coil and run it off 40 volts or so of a decent power supply (10 amps or so) and you have a 500watt IH just play around with the tank cap and remember that you will need to build a mmc to support the power being pumped into the work coil. Then you can go on to building larger IH's
Mon Nov 10 2008, 04:43PM
HFsstc-freak wrote ...
Arcstarter, your ZVS driver SUCKS!!! tongue tongue tongue
Ohhhh, so your the guy who said that to me on youtube? Like i said to that message, *laughs*.
Can we move on to the ZVS now and enough off topic stuff about how much my ZVS SUCKS?!?!
Myke, i did not make the ZVS for the induction heater, i am just experimenting. But, if i can get it to work properly i will use it for an experimental induction heater. I am no planning on making it all good and stuff, just hot enough to be able to bend stuff, for fun.
When i get a full wave bridge rectifier that is good for like 50 volts and 35 amps, i will hook the ZVS into my mot. I have some good filter capacitors that i got from alltronics(it was the 5 pound bag of misc caps, that i got for 10 bucks). I am planning on using a 8700uf 100 volt sprague powerlytic.
Antonio
Mon Nov 10 2008, 09:07PM
This driver is quite strange. With just the elements shown in the schematic it is not an oscillator and should not work. Indeed, a simulation of it doesn't work consistently. There is a tendency for both transistors to conduct simultaneously short-circuiting the power supply. If it works in practice, must be because of parasitic resistances, capacitances or inductances in the construction.
Mon Nov 10 2008, 09:32PM
Antonio wrote ...
It works in theory too, I don't know what's wrong with it. The primary LC just keeps oscillating by itself, the transistors just "poke" the resonant circuit. It's true that there's a small region where both conduct simultaneously (or at least partially), but they cannot s/c the supply because of the dc link choke, and again the tank circuit just keeps going, reversing teh polarity, and the diode feedback takes care of opening the right transistor.
Antonio
Mon Nov 10 2008, 11:16PM
Dr. Kilovolt wrote ...
In a simulation the circuit only works consistently, producing an almost sinusoidal oscillation, if some resistance is considered in series with the power supply or with the choke. Otherwise it may oscillate, but generating irregular pulses. The required value depends on the load. I am still looking at why this happens. In practice, the resistances are there, and so the circuit is expected to work, at least when not heavily loaded.
It's interesting to observe why the choke is needed. When the circuit is powered up, both transistors conduct simultaneously, drawing a quite high current pulse. The choke presents a load to both transistors, reducing both drain voltages, and eventually causing both diodes to conduct. When this happens, the circuit becomes unstable and starts oscillating. It then settles in a nonlinear oscillation filtered by the tank circuit formed by the capacitor and the two primary windings. Without the choke the diodes never conduct.
It also reduces the current at the intervals when both transistors conduct, of course.
Tue Nov 11 2008, 08:47AM
The choke works as a constant current source, without it the circuit could not work, because the tank circuit could not oscillate as it would theoretically draw infinite current from the supply ...
jovica
Tue Nov 11 2008, 10:47AM
Really?
I ran a zvs without a choke an it worked but the sparks were actually more purple than white. confused
can you expain this ?
Tue Nov 11 2008, 01:35PM
Tekken_LordS wrote ...
Maybe, if you had loose coupling in the primary (e.g. wound with thin wire) and a small resonant capacitor, it may badly work (transistors getting hot,...).
Another thing is that if you used a mains transformer just rectified and not filtered, its secondary can act as the choke. In this case the circuit would run perfectly fine without any choke.
Tue Nov 11 2008, 02:44PM
It works fine in a ferroresonant version with no choke, too. You get a square wave output, and the frequency is set by core saturation like in the blocking oscillator. You can make a ghetto inverter by driving a tube filament transformer backwards with it.
All of these push-pull oscillator circuits rely on an initial imbalance, or noise amplified by positive feedback, to get them started. In a computer simulation with no thermal noise and two identical MOSFET models, it might never start.
Sat Nov 15 2008, 02:34AM
Do you think maybe the irfp460's have too high Rds on? It is .22 ohms and the suggestion for Rds on, is .15 ohms. It doesn't sound like too much of a difference to me, but what do you guys think? I cannot recall anyone that used irfp460's but i am quite sure it is something else in my circuit, because i am sure someone out there has used an irfp460.
also, another thing is, i still have 20-30 turns on my inductor of thick wire, and apparently, the suggested amount is like 200.. So, is this where it went wrong? I am going to go make a new inductor and see what is gonna happen.
