  • Guests: 45
dumb igbt question
teslacoolguy
Thu Nov 06 2008, 06:59PM Print
I dont know how the tvs diode connects. I am assuming it goes across the gate and emitter after the 5.1ohm gate resistor. Am i correct? I know it is a dumb question but please correct me if i am wrong.
teslacoolguy
Thu Nov 06 2008, 11:53PM
Never mind i figured it out, can a mod please delete this thread.
LithiumLord
Fri Nov 07 2008, 12:41AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Just to put it more clear - yes, the TVS diode should just bypass the gate itself. Assuming you use a bipolar drive (as unipolar is pretty dull) you need a bidirectional one, but for the speed purposes it seems it's more optimal to use a serial pair of unidirectional ones instead.
