  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Ground
oucivileng
Tue Oct 28 2008, 10:45PM Print
oucivileng Registered Member #1772 Joined: Tue Oct 21 2008, 05:23AM
I'm trying to plug my NST into this old AC voltage regulator that I found but it doesnt have a hole for the ground. Does anybody have any suggestions for fixing this problem?
1225233839 1772 FT0 Dscf0668
1225233839 1772 FT0 Dscf0670
Myke
Tue Oct 28 2008, 11:21PM
See if there is any connection from the input plug to the case. If there isn't, you can out a ground wire to the case and use the case as a ground connection. I think it would be a good idea to do for safety reasons.
teslacoolguy
Wed Oct 29 2008, 02:16AM
You can just connect the nst ground to a water pipe. The ground has no effect on the variac but you might want to ground that to for safety reasons. Also i would suggest you resize those pics before a mod bites you.
oucivileng
Wed Oct 29 2008, 01:15PM
If I use a 2 prong adapter to plug the NST into the variac and ground the NST to the case, and then use a 3 prong adapter to run a ground from the case to the wall plug, is there going to be a risk of shock when I use the variac?
(does this even make sense? sorry, this isn't my area of expertise. I'm learning as I go)
Wed Oct 29 2008, 07:56PM
oucivileng wrote ...
This is suffecient grounding to avoid being killed, you will not avoid getting shocked as it will be you that makes your current leakage breaker trip :)
