  • Guests: 41
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
Audio modulated SSTC - Some design questions
aonomus
Mon Oct 20 2008, 05:46PM Print
Ok so for my next SSTC I'm planning on audio modulation, however I'm starting to run into a few roadblocks as I jump between SSTC and DRSSTC design documents/threads. Hopefully there aren't too many questions here, but the gist of this is that I'm trying to meld together some SSTC designs, while using a offboard modulator (that I can reuse for other projects).
1. PWM (TL494) or PLL (4046) - which one is better? I'm leaning towards using PWM with feedback, and an offboard external modulator.
2. Can I use a current feedback transformer on the secondary instead of an antenna for feedback?
3. Should I use primary current sense to prevent overloading my MOSFETs?
4. Should I build in a zero-current-switching circuit using a flipflop like out of the minibrute schematic so my interrupter does not cut off in the middle of a cycle?
5. While I'm planning on a Fres of 180khz and approximate power of 500W-1kW, should I bother to use fiber-optic input, or can I just get by using TTL over shielded coax with a BNC connector (shield grounded).
Edits to answer questions from IRC:
Target fullbridge voltage: 240V via a voltage doubler (with the possibility of a third stage if I'm insane).
Mon Oct 20 2008, 05:50PM
At your Fres it doesn't matter much.
Yes but it will be unstable if you get groundstrikes, it will most likely blow your bridge when that happens.
Always a good extra protection.
Audiomod coils usually run in CW mode so you don't need to sync anything
Shielded coax is better shielded then fiber optic transmitters and recievers.
Mon Oct 20 2008, 06:47PM
As to question 2, it depends entirely on feedback scheme. You'll need to decide that first. With the PLL drivers using PC2 it works perfectly, with PLL using a XOR comparator you'll need to use an antenna for stable operation. Basically it's a matter of how phases are added up to get feedback.
Mon Oct 20 2008, 11:20PM
Go with the Class-E design that i think Reaching (i think that is who did it) did. He has the design documented on his website.
Very clever design, and a nice high-side modulated driver too.
aonomus
Tue Oct 21 2008, 02:30AM
Hmm it would seem that his E-class SSTC page and the audio mod'd SSTC links don't work on his site...
Edit: Question about CT's - will any old torroid do, or must it be a high permeability core like those used for GDTs? At the rate winding torroids go I think I might end up just buying one for primary current protection...
Tue Oct 21 2008, 12:33PM
I've used random cores before and they give enough signal to make things work, but a GDT toroid will definitely work.
aonomus
Tue Oct 21 2008, 03:31PM
How well can the class E SSTC scale up? I've only seen small models yet I'm aiming for a line-powered 500W-1kW model....
At the same time I'm also aiming towards building a separate interrupter so I can use it to do PWM for a few other things. Should I go back towards fullbridge PWM drive, or is there some way a 4MHz class E can scale up....
Tue Oct 21 2008, 04:33PM
aonomus wrote ...
You could always just make a half or fullbridge.. It will no longer be class e though..
Tue Oct 21 2008, 05:19PM
I think Steve made a very powerful class E SSTC with a IGBT instead of a MOSFET not too long ago, there is a thread about it on the forum.
EDIT: I found the thread: Link2 quite impressive I must say..
Tue Oct 21 2008, 06:43PM
101111 wrote ...
I think Steve made a very powerful class E with IGBT not too long ago, there is a thread about it on the forum.
Yes, he did. He got some enormous sparks too, like a foot or somethin. I think all the changes he made to the class e he already had was use an igbt and higher voltage input.
