  • Guests: 45
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Mercury luminescence when shaken?!
Sat Oct 18 2008, 08:35PM Print
Really weird thing i found though, if you evacuate a tube partially filled with mercury, and then shake it you may get flashes of light from areas of the glass. it looks like a form of sonoluminescence
Might also work with galinstan as well as InBiPbSn and InBiSn alloys (59 and 61 Celsius = doable)
would be an interesting experiment to see if this works with metal combinations other than mercury
Download
Thu Nov 13 2008, 10:02PM
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
Fascinating, If I had some mercury I would try this out
Any idea if this would work with a mercury thermometer?
Sun Nov 16 2008, 07:56PM
Scott Fusare Registered Member #531 Joined: Sat Feb 17 2007, 10:51AM
It will not work with a thermometer as the mercury must be able to move freely over the glass surface.
Find some old glass mercury switches, they work well. Be sure to give you eyes sufficient time to dark adapt
as the effect is not bright by any means.
This light occurs due to charge separation at the Hg / glass interface. This effect was first observed quite a while back
in mercury barometers. If you Google on "luminescent barometer" you should find the historical references.
Scott
Bored Chemist
Mon Nov 17 2008, 07:20PM
Mutter mutter , health and safety, mutter fragile evacuated glass. Mutter dark room, toxic liquid, mutter mutter
aonomus
Mon Nov 17 2008, 07:52PM
I have a hunch that because alot of gallium alloys tend to wet glass, you'll lose the effect. I'd be interested to see what woods metal/fields metal does (if you can manage to keep it hot enough while watching for any luminescence....).
Edit: Not to mention that woods metal, while lead containing is a hell of alot safer than Hg....
Mon Nov 17 2008, 09:25PM
Yes, As "Bored Chemist" points out - glass is fragile, mercury very toxic and dark rooms problematic where safety is concerned. Be aware of the potential dangers before you try this.
That said, anyone with the presence of mind to walk and chew gum successfully should be able to perform the experiment without necessitating a visit from the HAZMAT team.
Myke
Tue Nov 18 2008, 03:09AM
I have always thought it would be cool to encase a tube half full of Mercury in a clear resin so it will be a lot harder to break if dropped. Would it protect the tube from being broken?
rp181
Tue Nov 18 2008, 04:23AM
It would help some, but the clarity cant be good, and i think its all avoidable if you just take some basic precautions.
Bored Chemist
Thu Nov 20 2008, 06:53AM
rp181 wrote ...
Why not?
plazmatron
Fri Feb 06 2009, 01:55AM
The luminescence is caused by static electricity. The action of the moving mercury on the glass walls strips and re-deposits charge from the glass, like the classic electrostatic machines.
A vacuum is not necessary to see the effect, but the ambient humidity must be low.
Leslie
