  • Guests: 49
adding a remote printer
scrooch
Sat Oct 18 2008, 08:14AM Print
scrooch Registered Member #908 Joined: Wed Jul 18 2007, 05:53AM
ok so i have been using SSH to ftp into the university printers from home.i use putty to SSH.
i login to the printer using Link2 put the .prn file into it
its a hp jetdirect.
i was wondering is there a way to add this printer to my normal list of printers on my laptop running vista home premium?
like when i want to print something from like say word, that printer will appear there and i just ave to select it?
is this doable?
Sat Oct 18 2008, 10:18AM
I imagine you can set your laptop up for "Standard TCP/IP printing" using a method similar to this: Link2
and then use PuTTY to forward the appropriate port to the printer. I've never tried it, though. You might need to select "Raw" instead of "LPR", and the port will probably be 9100.
Sat Oct 18 2008, 06:50PM
That would be your best bet, although if you can't make that work you might be able to do kind of a hacky method. I assume the printer will accept pdf documents (don't all network printers these days?), so just get a print-to-pdf printer driver and set the default file save location to
ftp://user:pass@printer.uni.edu
(filling in revent info of course).
scrooch
Sat Oct 18 2008, 11:18PM
thanks guys i'll try that and see how it goes
