  • Guests: 38
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Converting a SGTC to SISG
Bob J
Fri Oct 17 2008, 05:25PM Print
Bob J Registered Member #810 Joined: Wed May 30 2007, 05:23PM
Hi Guys,
Have heard a lot of great things about SISG coils and was wondering what it would take to convert my current coil (4" 1000 turn secondary, 12K/60ma NST etc) over.
Also was wondering if I can use Java TC for a SISG coil....
Any thoughts would be appreciated....;- )
Bob J
Sat Oct 18 2008, 12:50AM
I think all you would have to do is replace the spark gap with the sisg module. I am quite sure any sgtc calculator will work fine, the only difference is the spark gap which will not change anything. Same tank cap and everything.
Bob J
Sat Oct 18 2008, 02:24AM
Perfect! That was what I was hoping.....;- )
Thanks!
Bob J
LithiumLord
Sat Oct 18 2008, 11:47AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Just MAKE SURE OF THE CURRENT!
Or your SISG-module can fail due to pulsed overcurrent - the IGBTs can handle some overload even above the given pulsed current value from datasheet for such a short time the SISG firing takes, but it's still not unlimited.
Sat Oct 18 2008, 03:16PM
Also, every SISG I've ever seen was DC only. They only "spark" in the forward direction, and conduct in reverse like a diode. You'd need a high voltage rectifier for your NST.
Bob J
Sun Oct 19 2008, 03:16PM
Thanks guys for all the great info....
Am using boards that I got from Mark Dunn so nothing too exotic or different from the standard approach that everyone else seems to be using.... 12KV will need a lot of diodes to rectify so am thinking it might be simpler to just go with a rectified MOT (similar to the piranah)....
One quick question though..... With a rectified MOT/SISG configuration will I need to use a different capacitance value for my tank circuit.... I assume that the tank/primary/secondary/topload is already tuned as a resonant system and therefore should not need to be changed for a different charging/trigger system... Is this the right thought?
Am trying to avoid any part of the upgrade that does not need to be changed so I can have the SISG upgrade in place for halloween...;- )
Much appreciate the benefit of your experience and insight.....
Bob J
Sun Oct 19 2008, 06:25PM
No, there should be no need for changes to the tank circuit.
Yish on Ebay is selling some high voltage rectifiers.
Bob J
Sun Oct 19 2008, 07:03PM
Thanks! Will give Yish a look....;- )
Bob J
Sun Oct 19 2008, 07:27PM
Hi Steve
Couldn't find a YISH ebay store.... Assumed that I am looking at an array of 1N4007 for the rectifier... Do you have a link you could share?
Thanks again...
Bob J
Bamacoiler
Sun Oct 19 2008, 09:26PM
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
Hope that helps. shades
