  • Guests: 61
bridge cooling
Curtis
Mon Oct 13 2008, 10:19PM Print
Curtis Registered Member #883 Joined: Sat Jul 07 2007, 01:02PM
has anyone ever put a bridge into a vat of veggie oil to help dissapate the heat?
Crimson Rain
Mon Oct 13 2008, 10:45PM
Crimson Rain Registered Member #1745 Joined: Wed Oct 08 2008, 12:29AM
Curtis wrote ...
wouldnt mineral oil be better?
Shaun
Mon Oct 13 2008, 11:28PM
Mineral oil and vegetable oil will work the same but vegetable oil will begin to stink unless it is completely sealed.
That aside, I've never heard of anyone doing this, probably because oil is messy+heavy and you can usually get adequate cooling with just a heatsink and fan. Plus, oil is usually used primarily for HV insualtion. It's cooling properties are a convenient side effect.
LithiumLord
Tue Oct 14 2008, 09:41AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Probably you can try that - but what for? In the present version of my bridge I put both high-side fets on a wide CPU heatsink that I put face-down just to make a simple test layout for the first run. However even with no cooling fan at all it doesn't heat up that much (~45'C if checked by hand) so I left it like it is for now :) So four CPU heatsinks and two cooling fans will make your bridge never get warm - unless there's any problem in the electronics.
