  • Guests: 47
Primary tank characteristic impedance for a VTTC?
Marko
Sun Oct 12 2008, 07:03PM Print
First to say hello (haven't been opening threads for quite a while now);
I've ran into some problems I think you could easily solve.
What heuristics could I use to determine some ballbark surge impedance required, for any power level of armstrong oscillator VTTC?
I have a design with 3 6146's in parallel, which I hope to give me some 250-300W when pushed a bit. Power supply will be level shifted mains (halfwave 650V peaks). Resonant frequency is going to be about 2Mhz.
Looking at other people's designs (all with MOT's, though) the general surge impedances seem to be 200-400ohms.
But, I feel I need a lot lower for working voltage of only 600V or so... question is, how much?
Tank caps I have at my disposal are 680pF 20kV doorknobs, which I would like to center around. I don't know whether to use one or two caps in parallel, as start.
Thanks,
Marko
Mon Oct 13 2008, 10:22AM
I always recommend one-tenth of whatever they quote in the tube datasheet as the recommended load impedance. This allows for a working Q of 10. I saw this in a ham radio handbook originally.
With three tubes in parallel, you'll need another factor of 3: one thirtieth of the load for a single tube.
