  • Guests: 55
Anyone knows how this cirsuit works?
niccolo
Sun Oct 12 2008, 03:46AM Print
niccolo Registered Member #1679 Joined: Fri Sept 05 2008, 05:22AM
Hi all,
I am a newbie and having some fundamental question about the following schematic.
2n3055
Any one tell me the mechanism of the circuit? and the choose of resistors.
What I know is that it is a +ve feedback but I don't know the way the coils work.
Thanks.
Sun Oct 12 2008, 07:33AM
It works like this: The transistor is turned on through the 220 ohm resistor. This puts voltage across the primary winding, and also induces voltage on the feedback winding. Because of the way the coils are phased, this feedback winding forces even more current through the base of the transistor (this is where many people think the opposite).
The transistor is now opened and primary current starts ramping because of inductance. As the core gets near saturation OR the transistor cannot hold the primary current anymore (de-saturates), the voltage on the feedback coil falls turning the transistor OFF.
The energy stored in the core's air gap gets released in the form of a large negative polarity spike or "flyback pulse" on all windings, this is where the "HV" comes from. This spike also occurs on the feedback coil, holding the transistor OFF during the flyback pulse. As the voltages fall back to zero, everything repeats.
