  • Guests: 54
SSTC Costs
Crimson Rain
Fri Oct 10 2008, 04:58AM Print
Crimson Rain Registered Member #1745 Joined: Wed Oct 08 2008, 12:29AM
Just wondering the approximate costs for one of these builds? More specifically a DRSSTC? They seem a lot more expensive than good ol SGTCs
Ken M.
Fri Oct 10 2008, 05:05AM
Thy are!
In most cases your looking @ $12us-$120us just for the bridge, namely the igbts. Then ad the cost of the rest of parts I'd say its easily a $120-$300us coil. Just my guess. I could be wrong.
Dr. Drone
Fri Oct 10 2008, 04:36PM
shades
aonomus
Fri Oct 10 2008, 07:10PM
If its your first ever major project, I'd seriously recommend going with a SSTC:
- Capacitors are usually small(ish) in size and are typically single components where in DRSSTCs there are multi-mini-capacitor (MMC) banks which can end up costing *alot* of money.
- Easier to build, lower powers, simpler design
- MOSFETs are more common for SSTCs (whereas IGBT's are used more in DRSSTCs) - MOSFETs are cheaper than IGBT's
It also depends on what equipment and tools you have, if you don't have an oscilloscope it might be a bit of a miracle to get anything to work for a DRSSTC without one, but it wouldn't be so impossible to make a SSTC that runs off of feedback from an antenna.
Fri Oct 10 2008, 07:57PM
I think that with SSTC you get the most spark for your buck. To get a SGTC working decently you need expensive high voltage caps and a quality spark gap.
However, SSTC can be made using very little money, in fact my first one used two $1 transistors, other parts were salvaged or sampled, and it made 20cm sparks (@ Link2 ). In fact you can build one for free if you sample parts.
aonomus
Sat Oct 11 2008, 02:25PM
I sampled my MOSFET drivers, my MOSFETs, the only things that cost money were the PCBs, time to etch, and the copper wire/pipe.
