  • Guests: 24
oil cooled fly back driver
Chris Cristini
Fri Oct 10 2008, 02:17AM Print
i used a 18v cordless drill trigger and transistor but i doubled the input from 18 to 36 it got hot so i putt it all in a jar full of vegetable oil how can i lower the frequency so it is not so loud? its so loud it hurts.
CT2
Fri Oct 10 2008, 02:26AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
I have no idea what you did, and I'm not sure anyone else will, and that means no one can really help you. You used the variable speed controller from a drill as a flyback driver? But the output from the flyback, or the actual circuit is making noise? More detail on what you did would help.
Chris Cristini
Fri Oct 10 2008, 02:38AM
oh im sorry it is just when i draw an ark it is very high pitch did i do something that has not been done yet it makes nice high power arcs lol
Fri Oct 10 2008, 06:00AM
you use the single transistor driver right? If so try to wind the feedback coil tightly over the primary and put spacers in the flyback core if you haven't already.
Dr. SSTC
Fri Oct 10 2008, 07:04AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
No he used the simple pulse width modulator found in a cordless drill, its a bascicly a SMD ne555 with a couple of resistors conected to a slidble brush which is moved when you press the trigger, inturn changing the pulse width, which send a signal to a rather large mosfet +33 amps or so.
Ok to answer your question no you cant change the frequency that is why its called a 'fixed frequency pulse width modulator. Look it up on google cheesey
Chris Cristini
Fri Oct 10 2008, 12:55PM
ok i will get some pics of it so u all can see how big the arcs are its pretty cool
oh and i used one of the coils on the transformer it works better than my own coils on the core i must not be winding tight enough
teslacoolguy
Fri Oct 10 2008, 03:37PM
IT seems like your cordless drill oscillator is running in the audible range around 14-17khz and that is what is causing the loud hi pitch noise. If it is a 555 driving it then try to decrease the resistance between pin 7 and 8 and then decrease the resistance between pin 7 and 2 noting that pin 6 and 2 are connected together. there is also a capacitor on there that will give you a higher frequency if you lower it's value. Remember this is only if it is being driven by a 555 timer.
Chris Cristini
Sat Oct 11 2008, 01:07AM
i don't think it is a 555 timer the top numbers are cpx9 and the bottom numbers are e9538 it is a very small ic smaller than 555 but still 8 pins
this is my set up
1223686830 1749 FT55426 1111
this is my jar full of oil and i can get the arc much bigger it was a hard pic
1223687199 1749 FT55426 S6300715
1223687199 1749 FT55426 S6300719
1223687199 1749 FT55426 S6300717
1223687199 1749 FT55426 S6300718
can i dip my fly back in the oil to? will i get any losses in voltage or current.
[Edit: Don't post several times in a row, edit your previous post instead.]
Sun Oct 12 2008, 01:30AM
I wonder if this is not a squarewave oscillator? Maybe it is a sawtooth, like maybe an scr and diac? Because don't flybacks run only on squarewave? If it is like a magneto, maybe it only runs on one type of 'oscillation'. Magnetos run only on a sinewave, otherwise they have low output and heat up pretty bad.
Chris Cristini
Sun Oct 12 2008, 01:36AM
i am not to sure would i need an oscilloscope to find out?
