  • Guests: 63
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
capacitors
Matrex30
Thu Oct 09 2008, 01:48AM Print
Matrex30 Registered Member #1726 Joined: Tue Sept 30 2008, 08:03PM
Were can I get good capacitors? I have a budget of $20...lol
I have
-13.5 inch secondary wrapped 10.75 inches 27 AWG wire
-12kv NST 30mA
-Top load is a ball + aluminum foil =)
-Primary is some insu;lated wire wraped around it
please help me find The capacitors/capacitor for my tesla coil
I only want about 2-3 inches of sparks into the air
Thu Oct 09 2008, 03:09AM
Matrex30 wrote ...
I am not so sure you will be able to find a good tesla coil capacitor for 20 bucks, but miracles have happened! I will help you look around the web for some, perhaps i will find a good cheap one on ebay. You are old enough for your parents to let you go mow other's yards, right? If not, you should not be playing with tesla coils or high voltage. But you should just go around the neighborhood(if you live near people) and ask if you can clean up yards or mow grass or other lawn services(NEVER go into ANYONE'S house unless you know them). I make 100 bucks a week on good productive weeks. Then, buy some good CDE capacitors, and if your coil is built well you could get like 2-3 FOOT sparks! But, if you want small spark a neon transformer is a bit too powerful, use something like a flyback transformer or ignition coil.
Use a 555 timer and mosfet to drive 12 volts at an amp into a flyback and use that as your power supply and you should get about 5 inch discharges. That is VERY efficient! 12 watts can get you 5 inches. Apparently, with a 200 watt zvs driver you could get 2 foot sparks..
Coronafix
Thu Oct 09 2008, 10:00AM
Well....with the right design, you could get 30 inches with that NST!!
Of course this would require spending more thatn $20 on capacitors. cheesey
I would suggest making some salt water caps, this will cost you less than
$20, but I can't stress enough the importance of research.
Tesla himself said that he spent 90% of his life thinking, therefore when he
actually did things, he did them right.
You will need about 6 or 7 salt water caps to get the right capacitance.
Good luck.
Fraggle
Thu Oct 09 2008, 01:10PM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
You can probably make a capacitor for that money which will work for a bit. Use paper and tin foil and some oil.
Coronafix
Thu Oct 09 2008, 08:38PM
Actually that reminds me of Mates rolled caps. Link2
oucivileng
Tue Oct 21 2008, 12:59PM
oucivileng Registered Member #1772 Joined: Tue Oct 21 2008, 05:23AM
Mine are beer bottles in a tub of saltwater. The bottles also are filled with saltwater. Hang some long bolts or something into the bottles and connect them all in parallel.
