  • Guests: 66
So how do you think this will work out?
Crimson Rain
Wed Oct 08 2008, 01:03AM Print
Crimson Rain Registered Member #1745 Joined: Wed Oct 08 2008, 12:29AM
Im building a static spark gap tesla coil, and Im waiting on parts to come in, but have a general idea on how things will be put together. So, heres my setup:
12kV NST, 60 Hz, 30mA
RFI Filter
Cornell Dubillier 942 CDE .15 uF capacitor rated at 2000V (ill be making a string of 22 to get a capacitance of .00682 uF)
tungsten spark gap w/copper connectors
1/4" copper tubing (for primary, plan to do about 14 turns spaced at 1/4 inch)
22" secondary wound with 26# wire (approximately 1100 turns)
3x12" toroid
Heres a poorly drawn mod edit: and oversized and generally noobish schematic:
Tcsetupsd6
Please, correct me if Im wrong on anything, or give me some suggestions on how I could improve the setup. Thanks guys!!!
TheBoozer
Wed Oct 08 2008, 01:13AM
That's almost a perfect match to my first coil. I also added Terry's NST filter. It worked good. I upgraded to a propeller style rotary gap and it worked even better.
I made a vertical helix for my primary. I think I would have been better off with a flat pancake. Yours?
You didn't mention secondary O.D.
teslacoolguy
Everything is looking pretty good. One suggestion i would like to make is to replace the safety gap with a terry filter Link2 . It will extend the life of your nst more then a safety gap.
Coronafix
Wed Oct 08 2008, 03:08AM
I think your capacitor is too small. LTR for your NST is about 10nF, you could use a string of 15 to achieve this and still have a voltage rating of 30kV.
Crimson Rain
Wed Oct 08 2008, 03:43AM
TheBoozer wrote ...
Yeah, I plan on doing a flat primary lol. And my outer diamter is about 4.2" on my secondary
teslacoolguy wrote ...
I was debating on whether or not to add a terry filter, so I think I will
Coronafix wrote ...
Ive tried out some online calculators (deepfriedneon.com's for example) and they calculated it to be .0066 for my transformer, so I dont know :S
Coronafix
Wed Oct 08 2008, 08:16AM
6.63nF is your resonant cap size (I'm assuming 60Hz line frequency) for a 12kV30mA NST. With a static spark gap
it is recommended that you use a larger than resonant capacitor, usually 1.4-1.5 times resonant value.
This gives a cap value of 9.3-9.9nF. At resonance your cap can see some extreme voltages and even though you have
a bank design that could handle that, chances are your NST won't survive this. More info here Link2
Crimson Rain
Wed Oct 08 2008, 01:49PM
Coronafix wrote ...
Thanks, that information was very helpful. Im going to change my cap chain to about 16, giving me a capacitance of .00938 uF. If needed, I can remove one for a nice clean 0.01 uF. Theres always time for experimentation cheesey
