  • Guests: 56
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
ebay - QRP transmitters-on-a-chip?
Hon1nbo
Sat Oct 04 2008, 11:33PM Print
66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
Are these any good to at least get started with?
Sun Oct 05 2008, 03:11AM
They are just a crystal oscillator, not a full transmitter as the description would imply. You still need some kind of rf amp and antenna and impedance matching and all that.
Bjørn
Sun Oct 05 2008, 11:26AM
Crystal oscillators will give off radiation so they are transmitters in that sense. They are just not very good transmitters.
One problem is the square wave output that will make it transmit on multiple frequencies unless you filter it. With a good and well matched antenna you gan get quite impressive range from one of those.
Just buy the cheapest crystal oscillator you can find that has the right frequency. Remember that a crystal alone will not oscillate so you need one of those chips with a built in oscillator or make the oscillator yourself since the crystals are much cheaper.
Chris Russell
Sun Oct 05 2008, 06:15PM
Chris Russell ... not Russel!
I have used similar devices. They are generally just keyed using the output enable pin, rather than the power, as shown, to reduce chirp.
They aren't the greatest thing in the world. There's generally always a small amount of chirp as you key down, and as Bjorn pointed out, the output is a square wave, so you'll need to filter the output.
You can use a high speed CMOS buffer as an amplifier for one of these chips, and get a half watt or so out. You can then also key the CMOS output enable, and get rid of most of the chirp.
As they are now, don't expect much range. A few hundred yards, maybe more with a good antenna. With a CMOS acting as an amp for 250-500mW out, into a good antenna, anything within line of site and perhaps a little beyond should be possible with CW, assuming they are paired with a good receiver.
Note that the AM modulation scheme shown is a bad idea. These things are not frequency stable with respect to input voltage, so it will FM as well as AM, and the signal won't be very nice.
For the price, I probably wouldn't bother unless you have something specific in mind. If you want a one-chip low-parts transmitter, check out something like this: Link2 . If you use sockets or switches for the crystal and filters, it can operate over many bands.
Hon1nbo
Sun Oct 05 2008, 08:51PM
I found a place locaklly that sells crystal oscillators and all the stuff I need to filter the output (and amplify it) and the total parts are cheaper than this (minus the keyer) :P
