  • Guests: 48
Future VTTC teaser
Sat Oct 04 2008, 07:49PM Print
Here is a couple of shots of my QB5/2000 tube, got the filament transformer yesterday so it was about time to test the transformer and tube. I got the socket from the "local" hongkong ebay seller :D
Transformer is rated 7.5V / 32A, its from an old Phillips stove.
QB5/2000 specifications (datasheet max values)
filament 7.5V / 22.6A
frequency 30MHz
Anode voltage 5.5kV
Anode dissipation 800W
Anode input power 3.5kW
Anode current 700mA
Grid 2 voltage 800V
Grid 2 dissipation 120W
Grid 1 voltage -500V
Grid 1 current 35mA
Planning to run it using 2 mots with levelshifter, controlled by a variac, and thats about the plans so far. I will need to plan a heavy frame for this build, all that transformer iron weighs down real good :D
1223149776 1403 FT0 Img 1287
1223149776 1403 FT0 Img 1288
MRacerxdl
Sun Oct 05 2008, 01:37AM
WoW! That is a valve to do big arcs.
and burn some filament transformers. 22A o.O
Good luck with the VTTC!
