  • Guests: 62
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
PlasmaSonic II based SSTC, with poor performance
1 2 3 4  last
Cotlone
Tue Sept 30 2008, 11:49PM Print
Cotlone Registered Member #1383 Joined: Mon Mar 10 2008, 11:09AM
Hey guys, this is my first post here so firstly I’d like to say g’day to everyone. This is also my first attempt at building a coil of any sort.
Ok but the real purpose here is to see if anyone can help me out with my SSTC and its apparent lack of output. I’ve based my coil nearly completely on the PlasmaSonic II, though I’ve culled its ability to generate long sparks and I am focusing on its acoustic performance. I can only get the device to generate spark/discharge with the base of the secondary moved within reasonably close proximity of the discharge terminal. This spark is at best about 20mm when my input is 200V but does play music, despite the terrible quality. The system should be well capable of delivering corona discharges on its own, so far - nothing. I’ve attached a couple of photos and schematics to help explain my setup and circuit.
I had initially made an error on the schematics prior to printing the board. I forgot to inverse the gate signal on two of the gates. To do this I’ve been running the wires from the incorrect GDT to the appropriate tracks on the board. These wires need to run past the toroid itself coming pretty close, I was wondering whether this will cause the not so clean switching signals I’m getting.
I should also say that the MOSFET driver chips were getting pretty hot and occasionally still do (will this happen if poorly tuned?) and the old GDTs became very hot too. That is until I blew one of them up (broke into pieces), along with two MOSFETs. I thought that I'd perhaps wound my previous GDTs too tightly. There shouldn't be a problem with heat in my current setup as I've since added a fan directly above the MOSFET heat sinks.
... and here are some details,
Primary coil : 12 turns, 3.15mm diameter
Secondary coil: 1220 turns, 0.4mm diameter
Secondary cap: Total capacitance > 8pF, but not sure
Resonant freq: I think it is around 300kHz, but this could be my problem
GDT : 12 Turns trifiliar, type 77 material
MOSFETs : IXFN48N50
Ok so let me know what else you’d need to know about the setup. Thanks very much for any help I really appreciate it.
- Cotlone
1222818542 1383 FT0 Coil
1222818542 1383 FT0 Spark
1222818542 1383 FT0 Dead Gdt
1222818542 1383 FT0 New Gdts
]schematics.pdf[/file]
]pcb_layout.pdf[/file]
MRacerxdl
Wed Oct 01 2008, 12:14AM
Some times here, it happens to the Mosfet Driver burn and doesnt get killed, it only makes a very poor GDT Driving and heats much, and the sparks at secondary stay at few mm. And when I trade the mosfet drivers for new ones, it back to work. Try that, maybe it work.
Cotlone
Wed Oct 01 2008, 12:29AM
Yeah I had replaced all of the driver chips, and changed them from TC4422s to UCC37322s. I had hoped that was the problem before. I have also replaced all of the MOSFETs since the failure.
KresoLiubov
Wed Oct 01 2008, 06:51AM
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
Simple enameled wire for GDT? You need to use wire like from CAT5 cable
Cotlone
Wed Oct 01 2008, 12:37PM
So the insulation is rubbish in the enameled wire? This would be contributing to poor gate signals then? I'll try rewinding them then with other stuff.
Cheers
KresoLiubov
Wed Oct 01 2008, 02:22PM
Cotlone wrote ...
Cheers
In such use you need to consider enameled wire insulation as it does not exsist
Dr. Drone
Wed Oct 01 2008, 03:17PM
shades
Tom540
Wed Oct 01 2008, 08:32PM
Tom540 Banned on 3/17/2009.
I find it weird everyone is so anti magnet wire. Thats what it was designed for. Just paint your core and youll be fine. The main reasons I use cat5 is simply because its easier to strip is color coded and is cheaper that magnet wire. Not because im worried about shorts. Ive never had a short from using magnet wire.
Dr. Drone
Wed Oct 01 2008, 08:34PM
shades
Cotlone
Wed Oct 01 2008, 11:59PM
Thanks for the replies everyone,
I've rewound the cores this morning and I'll stick them in soon as I can. I tied a knot in one end of my three wires and then twisted them together, I've then wrapped 15 loops around the toroid cores.
Is there a general rule for the coupling of coils? I thought that SSTCs were generally pretty highly coupled ie over about 0.35 or so, I could be quite wrong though.
So once I get these new GDTs tested I'll see how the performance is and have a look at my DC blocking caps.
Thanks for your help guys, I'll post my findings up soon.
1 2 3 4  last
