  • Guests: 39
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Need suggestions for tesla coil secondary terminations.
Tue Sept 30 2008, 11:23PM Print
I am going to start making 2 inch by 10 inch tesla coil secondaries, and i want to make them look and work good. I am going to drill a small hole right about the last winding on the top and bring the wire inside of the secondary, and place a top cap on it so the buyer can drill a hole himself and insert the size bolt or breakout point that he needs.
But i am wondering how i should make the bottom termination. I would like to have a metal bolt and nut with the wire connected to it with a ring terminal on the outside, so the owner can attach their own wire to the ring terminal for the grounding wire, but i am afraid that will either cause racing sparks, or sparks to their primary.
rp181
Tue Sept 30 2008, 11:55PM
arcing inside the secondary might be a problem.
Wed Oct 01 2008, 12:19AM
rp181 wrote ...
Good point... Any other suggestions? Well actually i doubt anyone would get sparks that big from it, i mean it would have to be bigger that secondary length to arc on the inside. Or are you talking about wire to wire or something else?
Also, what should i use to coat the finished coil with? Anything good at home depot or lowes?
Dr. Drone
Wed Oct 01 2008, 03:18AM
shades
Wed Oct 01 2008, 01:34PM
Dr. Spark wrote ...
Secondary should be sealed with wire on the outside. rolleyes
cheers,
ch
Well, since you said that i will just wind the coil and include the two end caps. I will let the owner do whatever they want with it.
Herr Zapp
Wed Oct 01 2008, 11:24PM
This topic was discussed at some length earlier this year (March), with many good suggestions given, including detailed photos of various techniques.
Search "secondary coil terminations", March 8 2008.
Also, any reasonably well designed and tuned Tesla coil should be capable of generating output arcs and streamers 1.5X - 2X the length of the secondary, so internal arcing can be a cause of secondary failure.
Regards,
Herr Zapp
