  • Guests: 41
Help me please with my tesla coil!
Matrex30
Tue Sept 30 2008, 08:38PM Print
Matrex30 Registered Member #1726 Joined: Tue Sept 30 2008, 08:03PM
Hi guys I just recently put together my Tesla Coil! Yay. But I have a problem. Im not getting any sparks. Here are my specifications
  • Spark Gap tesla coil
    13.5 inch secondary with 2.75 inch diameter and 701 turns of 28 AWG wire
    Wire wraped around 100 CD holder top thingy (crapy)
    12,000 imput voltage
    4 beer bottle caps
    1 inch spark gap
    Ball wraped in aluminum foil as top load
Ok below is how I connected it
Tesla
Please if im doing anything wrong please help me!
CT2
Tue Sept 30 2008, 09:13PM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
Your capacitor should be in series with the primary (like it is) but the spark gap should be across the transformer. Also 1" spacing for the spark gap seems a little large, set it so that it just fires when it is the ONLY thing hooked up to the transformer.
EDIT
Just like this Link2
Matrex30
Tue Sept 30 2008, 10:33PM
Ok I rewired it just like this
Tesla2
Ok and the arc jump from the spark gap is .5 inches spaced and I get a plasma arc....no power coming off the top load
MRacerxdl
Wed Oct 01 2008, 12:21AM
Try to change the primary tap. That is usually out of tune.
PS: The plasma arc is bright white or yellow/orange?
Cain
Wed Oct 01 2008, 11:37AM
Cain Registered Member #624 Joined: Tue Apr 03 2007, 07:50AM
it also looks like your caps are in series not parallel bottle caps should be in parallel for higher capacitance
Matrex30
Wed Oct 01 2008, 12:25PM
The arc is a Yellow/orange arc
MRacerxdl
Wed Oct 01 2008, 10:22PM
Yeah I think the same like Cain, usally yellow/orange arcs is like the cap isnt charging. Put it in parallel (the external sides together gives you one side, and the internal sides together gives other side) and try it again.
Matrex30
Thu Oct 02 2008, 01:41AM
I fixed it I just needed to Connect the capacitors the right way thank you Cain.
