  • Guests: 82
levitating toy
DrZoidberg
Sat Sept 20 2008, 07:16PM Print
DrZoidberg Registered Member #350 Joined: Mon Mar 27 2006, 05:14PM
A toy that uses static electricity
I wonder. Is it just a plastic stick that is rubbed or is there more to it?
edit:
There is a small van de graaff generator in that stick.
I think it's an interesting toy.
Antonio
Sun Sept 21 2008, 02:36AM
Looks active. Note in the video when the wide ring is picked with the wand and charged.
Probably an electronic negative ion generator is used.
aonomus
Sun Sept 21 2008, 02:44AM
When the ring is collapsed it doesn't want to 'fly', perhaps its just a alternating magnetic field inducing eddy currents through the plastic (aluminized mylar?)
DrZoidberg
Sun Sept 21 2008, 04:52AM
Every site I found about this toy says it countains a VDG.
I found another video. I think it shows that that stick really is using static electricity.
Antonio
Sun Sept 21 2008, 01:52PM
Yes, the wand can contain a small VDG. Note in the video a motor noise when the demonstrator pushes the button on the wand. An electronic HV generator would have problems in generating enough voltage, and could be dangerous. The effect is obviously electrostatic. Demonstrations of this kind, using feathers and frictioned bodies, are described in many old texts about electricity.
Fri Sept 26 2008, 09:02PM
Hmm. Piezo transformer(s) + small Tesla coil secondary tuned to Fr of piezo transformer? might work.
-A
Antonio
Fri Sept 26 2008, 11:16PM
Conundrum wrote ...
-A
A Tesla coil doesn't produce a static charge.
Avi
Sat Sept 27 2008, 10:32AM
i tried charging a TC topload to 50kv DC and put a very thin and light foil ring on top of it, it just flys off the top. Is there some sort of trick to make it stable?
Sat Sept 27 2008, 11:17AM
Some law of physics states that no stable arrangement of fields can cancel eachother, or something to the same effect. The trick to making it stable is constantly adjusting the topload position to counter the tinfoil's movement.
Aha! I knew I hadn't made it up. -> Earnshaw's theorem.
Experimentonomen
Sat Sept 27 2008, 12:30PM
Looks faked to me.
