  • Guests: 51
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Could Onion be a source of H2SO4?
Dragon64
Fri Sept 19 2008, 01:24PM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
Well, I learned that onion's produce a chemical sulfenic acid when the onion is cut. Since that sulfenic acid is highly unstable and rearranges to form C3H6OS (Syn-propanethial-S-oxide)
When C3H6OS reacts with water, this form sulfuric acid.
Would anyone, know the concentration of sulfuric acid generated by this method?
Danielle
Fri Sept 19 2008, 06:57PM
I am sorry for making a usless post, but well first of all you will need alot of Onions! that is if the rxn takes place with out a catalyst.
Hon1nbo
Sun Sept 21 2008, 03:06PM
I remember reading a about this reaction before, but I cannot recall where, but IIRC it is a very small amount, and is immediately diluted by other liquids present in the onion (even though presence of liquid is small, acid is smaller)
get something you could test it with, pH strips are very cheap and many things react in such a way that even a small reaction should be noticeable
I am sure someone or something knows... might be a good research topic.
Bored Chemist
Sun Sept 21 2008, 03:41PM
At best the yield will be very low. Also the sulphur compound produced is in the wrong oxidation state to form sulphuric acid by reaction with water.
Mon Sept 22 2008, 09:12AM
Just as well, otherwise onions would be pretty dangerous to eat.
